Instruments and Amps Everything that makes music, Especially including instrument amps.
show your creative clipping circuits
Old 2nd August 2018, 06:22 AM   #61
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Mine was a "gas pedal" with sneaky matrix of germanium diodes and resistors in feedback of opamp. With corresponding EQs before and after it. While playing a solo guitar I could gradually and smoothly change tone, from clean to wild overdrive. It was in early 80'Th when I played in a band... May be one day I will design and build an improved version of it.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 2nd August 2018, 11:39 PM   #62
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by PRR View Post
I can do moose:
I'm pretty sure I don't want to be clipped by a moose. Creatively or otherwise.
-Gnobuddy
Old 2nd August 2018, 11:55 PM   #63
Originally Posted by Wavebourn View Post
...matrix of germanium diodes and resistors in feedback of opamp.
In post #32 and #33 of this thread, back on page 4, there are a couple of implementations of piecewise-linear transfer functions using diodes and resistors in an opamps feedback network. No germanium diodes, though, as they are scarce these days.
I've seen a slightly different diode/resistor network used in analog audio function generators to shape a triangle wave into an approximate sine. But though the details are a bit different, the end result is the same, still a piecewise-linear approximation to a desired nonlinear transfer function.
-Gnobuddy
Old 4th August 2018, 12:22 AM   #64
PRR is offline PRR  United States
PRR's Avatar
Bad Germanium transistors are still a glut on the market. All but the real duds have one good junction.
Old 16th August 2018, 01:54 PM   #65
Guitar.mod is offline Guitar.mod  Europe
Originally Posted by guvoo View Post
was wrong, with the Diodes it does not show up this Level of distortion as with the transistor based diodes.
This configuration (schematic showen in the post 55) sounds quite good. As good as Si+ Ge diodes, but much more complex
Sound sample attached. (Used in opamps negative feedback as other examples)
Old 16th August 2018, 10:40 PM   #66
Thanks for the sound sample!
May I ask - for that sound clip, did you have any bass cut in front of the clipping stage, or just flat-frequency gain?
-Gnobuddy
Old 17th August 2018, 08:31 AM   #67
Yes, here it is small first order bass cut till gain reaches 1x. At the first (driver's) non-inverting opamp with 11x gain there is 1k + 470n from -in to gnd at the feedback path.
I am planning to play with multistage dynamic lowcut (an example of one stage is attached), because when gain is Higher or signal is stronger it is better to have more low cut, but when signal is weak, it sounds too weak when bass is cutted much, so it sound better when left almost flat.
In the first sound sample, where is demonstrated clipping performance of Ge+Si, there was three stages of low cut filters. (160Hz at first input; 340Hz at negative feedback; 340Hz at second stage input of inverting opamps configuration.)
show your creative clipping circuitsHide this!Advertise here!
Show me your screen drive circuits deicide67 Tubes / Valves 175 11th October 2013 09:14 PM
Show me your fave phonostage circuits. Poindexter Tubes / Valves 19 2nd November 2012 10:47 AM
Recovery from clipping, soft clipping hahfran Solid State 49 23rd February 2010 02:03 AM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 01:50 PM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 06:48 PM
Copyright ©1999-2019 diyAudio
