Instruments and Amps Everything that makes music, Especially including instrument amps.
Building Marshall Lead 100 MOSFET
Old 11th January 2019, 09:46 PM   #51
voltwide is offline voltwide  Ireland
With full overdriven square and 8Ohm Speaker at +-50V supply rails 39Vrms might be obervable for a short time (until the speaker is burned).
tuby or not tuby, that is here the question!
Old 12th January 2019, 07:44 AM   #52
Mooly's Avatar
Try this...
With NO load attached adjust the output to give 10 volts rms as measured on the meter. The scope will show around 14 volts peak (28 volts peak to peak).
Now connect your 8 ohm dummy load to the output.
The amplitude should remain unchanged. Does it ?
Old 12th January 2019, 08:01 AM   #53
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
If you truly want the "Marshall" sound then you are going to have to splash out on a 100 watt Marshall valve amp.
The valve pre amp Marshalls sound ok but don't match the full valve versions.
PCBCAD51 download or CDROM 2019 version out now http://www.murtonpikesystems.co.uk
Old 13th January 2019, 02:57 AM   #54
thoglette is offline thoglette  Australia
thoglette's Avatar
Agreed, but you don't need to run at 50 or 100W
One watt can be done (thanks to RobRobinette, again).
Old 14th January 2019, 03:48 PM   #55
jrow is offline jrow
The point is that I wanted to make a solid state amp with good reputation. I made it, as you can see in earlier posts, but I have to change some stuff to fit another pair of FET's that aren't the original ones.
My intention is to learn a bit of electronics (this is my second amp project), and this amp is perfect because it can be made with few components and mosfet gain is interesting.
Old 14th January 2019, 04:45 PM   #56
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Please do the 6 tests suggested in post#49 and post results.
We need one set of consistent measurements to be able to diagnose your amp by "remote control".
You are posting non matching values measured under different conditions, that is useless.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 14th January 2019, 05:14 PM   #57
thimios is offline thimios  Greece
Wrong resistor!
This is a 33 Ohm.
You need 0.33R.
You must see R33,NOT 33R.
Old 22nd January 2019, 06:58 PM   #58
shanx is offline shanx  Canada
Good catch, that would account for a lot
Building Marshall Lead 100 MOSFETHide this!Advertise here!
Marshall Mosfet LEAD 3210 blowing power fuses - help locating capacitor(s) jmilch Instruments and Amps 13 20th August 2009 05:31 AM
Marshall 2196 lead cab alexidoia Instruments and Amps 1 6th May 2008 08:16 PM
Marshall Super Lead MkII microslav Instruments and Amps 5 15th March 2005 07:59 AM
Copyright ©1999-2019 diyAudio
