Instruments and Amps Everything that makes music, Especially including instrument amps.
Building Marshall Lead 100 MOSFET
Old 5th October 2018, 02:49 PM   #21
jrow is offline jrow
Originally Posted by JMFahey View Post
Which Mosfets did you use? Where did you get them from?
The FETs are a pair of BUZ900, BUZ905 from Farnell. In datasheet they put a power dissipation of 125watt instead of original sk134 and j49, which is 100watt channel dissipation.
Old 6th October 2018, 03:49 PM   #22
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Thanks.
Ok, when you measure what I asked earlier we will know whether your amp works reasonably well and just does not "seem" to be that loud or whether we have an Electronic problem.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 3rd November 2018, 11:32 AM   #23
Okay,
I've discovered a few things scoping the output of the amp.
First of all, I was WRONG telling that the volume was low. The amp is able to sound strong, but the problem is that a distortion appears at a mid-low volume.
The distortion seems to be like a fuzz pedal. When the volume is low, the amp works without that distortion. It sounds completely clear, but quiet.
But scoping the output, I realised that the origin of distortion wasn't clipping: I injected 1 kHz increasing volume in a preamp, and these were the results.
input 1khz (convert-video-online.com) (1).mp4
As you can see, clipping is in a higher level than the distortion that makes the amp at a mid-low volume.
So, I measured the voltage in output, just before clipping in scope (no speaker attached). The AC voltage in output is 3.7 V. See what happens when I connect at this point the speaker. The distortion appears, and it sounds.
I tried it with a guitar too. When I'm playing softly, or at a low volume, it sounds clean. Even when I scoped the output without the speaker, the amp didn't seem to make the distortion that makes when I put a load to it.
ddd (convert-video-online.com) (1).mp4
Old 3rd November 2018, 11:39 AM   #24
And these were my attemps to solve the problem (surprise... no)
I put a TRIMMER in the R54 but I didn't change ANYTHING!!! I mean, the trigger was of 1kOhm, and in the schematic R54 was of 100Ohm. Okay, I set the trigger to 100 Ohm to go up or down... and when I put to 0 Ohm or to 1kOhm, the sine wave doesn't even react.
I put a gain pot (50k linear) in R61 (Originally 10k) but this reacted normally. As I increased gain, output was increased.
The problem is the distortion...Why?!!!
Old 3rd November 2018, 12:12 PM   #25
I missed a thing:
I measured the DC supply. It was perfect (+47.9 to GND and -47.9 to GND) even symmetric.
Old 3rd November 2018, 12:21 PM   #26
If you can't see the video, here are some screen frames.
Old 3rd November 2018, 01:02 PM   #27
voltwide is offline voltwide  Ireland
the video shows some current limiting effect when loaded with 8 ohms. did you check supply rails under load?
Old 3rd November 2018, 03:27 PM   #28
Hi voltwide,
This is how the rails looks like:
The amp switched on with -inf db signal: +47.9 V // -47.9 V
The amp switched on with low volume and no distortion: +47.7 V // -47.7 V
The amp switched on with maximum volume: +46.0 V // -45.8 V
I think this little drop is normal, isn't it?
Old 8th November 2018, 11:06 AM   #29
Plzzzz help !!!
Old 8th November 2018, 12:07 PM   #30
Mooly's Avatar
I have seen two very obscure problems cause distortion like that.
1/ Having a ferrite cored inductive component in series with the load. This can be something as small as a ferrite bead slipped over one of the output leads somewhere. The material saturates and gives this weird distortion... more likely an issue at high frequencies though.
2/ Another inductive issue can be having a shared magnetic component (such as a dual wound ferrite core) in series with each rail. Mutual coupling between the supply currents again causes this odd effect.
Beyond that and its a case of scoping rails and seeing if anything is apparent. The volt drop is normal, however the rail should still remain clean though and with only a little ripple showing.
Building Marshall Lead 100 MOSFETHide this!Advertise here!
Marshall Mosfet LEAD 3210 blowing power fuses - help locating capacitor(s) jmilch Instruments and Amps 13 20th August 2009 05:31 AM
Marshall 2196 lead cab alexidoia Instruments and Amps 1 6th May 2008 08:16 PM
Marshall Super Lead MkII microslav Instruments and Amps 5 15th March 2005 07:59 AM
Copyright ©1999-2019 diyAudio
