Instruments and Amps Everything that makes music, Especially including instrument amps.
Given one 12AX7 how would you run it given the rest of the amp is SS?
Given one 12AX7 how would you run it given the rest of the amp is SS? Please consider donating to help us continue to serve you.
Old 20th February 2020, 08:22 PM   #71
Gnobuddy is offline Gnobuddy  Canada
Originally Posted by Printer2 View Post
...I have other voltages...
In case it's useful: a lot of HP inkjet printers have a 32 volt DC power supply, and I've seen these in a Value Village or other thrift store many times. Most of the time the HP power supply has an oddball 3-pin connector, with zero, +16V, and +32 volts on the three pins.
These make good op-amp power supplies with a little additional RC filtering, and they may be good for feeding the 400 volt step-up switching power supply too.
-Gnobuddy
Old Yesterday, 03:26 AM   #72
Printer2 is offline Printer2  Canada
-Gnobuddy
The 32V ones only do about 0.5A (too lazy to run downstairs to check). The 12V ones I want to see 2.5A minimum. The most I seen is 60W out of a brick. 19V looks like it might be ideal in terms of a Class D amp given the voltage and current ratings. I can see a 12V for heaters and another brick to boost up for the HV for a 30W tube amp. One day I have to catalog what I have for voltages and current ratings. At $2-5 in the thrift stores it looks like adapters are my version of a woman's shoe fetish. I have resolved to stop buying them. That is unless I come across really small ones in the 25-35V range for bias supplies.
Given one 12AX7 how would you run it given the rest of the amp is SS?Hide this!Advertise here!
12ax7(ecc83) and 6n2p 12ax7...........differents?? plig88 Tubes / Valves 2 26th January 2013 09:14 PM
Amps for the rest of us? dzzmiller Full Range 44 6th April 2009 05:18 PM
for sale: the rest of my stuff. vincentrubble Swap Meet 10 15th February 2008 05:45 PM
May he rest in peace! Audiofanatic Everything Else 3 5th July 2003 11:55 PM
Goeie dag, G'day, and Hi to the rest. JDeV Introductions 16 8th November 2002 01:33 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
