Instruments and Amps Everything that makes music, Especially including instrument amps.
O/P Transformer DC Resistance Check
Old 14th June 2019, 07:33 AM   #51
trobbins is online now trobbins  Australia
trobbins's Avatar
In a PP stage, 350Vrms from plate to plate is 250V peak from either plate to CT.
The nominal primary impedance is 8k for push-pull with 8 ohm secondary, so that is the starting point.
Both Grant Wills and Frank Hughes showed 17W clean max level in to 8 ohm resistive load with 270-300V B+ in a fixed bias, UL configuration, so that's a good start for the M1115 with 6CM5. I'm hoping to repeat that setup soon, and will try and get some power-bandwidth and distortion info for both non-UL and UL configuration.
O/P Transformer DC Resistance CheckHide this!Advertise here!
Output transformer DC resistance jpdesroc Tubes / Valves 9 31st December 2018 12:05 AM
Heater-cathode DC conduction resistance trobbins Tubes / Valves 7 1st September 2018 03:27 PM
Transformer secondary resistance argonrepublic Power Supplies 7 1st February 2013 09:11 AM
Planar magnetic DC resistance vs. impedance? Few Planars & Exotics 8 18th February 2012 12:09 AM
Why does a driver need to have DC resistance goldyrathore Multi-Way 35 25th July 2004 06:42 PM
Copyright ©1999-2019 diyAudio
