Instruments and Amps Everything that makes music, Especially including instrument amps.
Valve Preamp for voice / guitar purpose
Old 13th August 2010, 06:45 AM   #1
aguantesoda is offline aguantesoda  Argentina
Send a message via MSN to aguantesoda
Default Valve Preamp for voice / guitar purpose
Hello, I want to put an ecualizer with a ba3812l in this circuit.
You think that this could work? (I donīt know the maths). The valve and the ba3812l can work together? or maybe all this sucks?
The original circuit maybe came from a mesa boogie, but Iīnot sure.
Guido
Edit: V1 and V2 are 12aux7
Old 14th August 2010, 01:56 AM   #2
mashaffer is offline mashaffer  United States
Gack! Why build a valve amp at all in that case? For guitar you are going to be better off with a traditional tone stack I suspect. I think it would be difficult to come up with a preamp that is appropriate for both guitar and voice.
If you are not a part of the Solution... you are a part of the Precipitate
Old 14th August 2010, 10:51 AM   #3
teemuk is offline teemuk  Finland
What's the signal level at the insertion point? Will it overdrive the EQ chip?
Depending on that you may or may not need to attenuate the signal before driving the EQ circuit. Otherwise, yes, it should work.
Old 18th August 2010, 11:59 PM   #4
The signal level on input is mi guitar:
Guitar -> ba3812l -> 12 Ax7 ----> to the power amp
Old 19th August 2010, 12:31 AM   #5
Thanks teemuk, you are right; the signal level at the insertion point isnīt overdrive the EQ chip; so, I can put the Eq first, and the 12ax7 after
Valve Preamp for voice / guitar purposeHide this!Advertise here!
TL Audio VP-5051 Valve voice processor Robbo67 Tubes / Valves 0 6th May 2009 03:03 PM
A valve pre amp for my disco and electric guitar. nigelwright7557 Instruments and Amps 4 12th June 2008 11:44 PM
big valve traffo for guitar amp? Craig405 Instruments and Amps 15 9th October 2007 10:53 PM
Multi-purpose tube amp (line and guitar inputs) smsmonster Instruments and Amps 28 20th May 2006 01:12 AM
valve preamp mr l Tubes / Valves 5 24th October 2004 04:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
