Instruments and Amps Everything that makes music, Especially including instrument amps.
Post your DIY Musical Instruments/Amps here!
Old 24th April 2010, 02:21 AM   #21
benb is offline benb  United States
Hi folks, I found DIYaudio through links from other audio places and websearches related to multiway speakers and crossovers, but I saw this thread and thought members would appreciate a DIY effort of mine from ten years ago:
http://web.archive.org/web/200204110...m/~benbradley/
I have a bunch of guitar-building books, and the most influential was "Guitarmaking:Tradition and Technology" by Cumpiano and Natelson. I've tweaked it over the years and it's as playable and good-sounding as ever.
Old 14th May 2010, 06:17 AM   #22
chris661 is offline chris661  United Kingdom
chris661's Avatar
That's a really nice guitar. Looks very professional.
My work: www.grimshawaudio.com
Old 29th May 2010, 09:25 AM   #23
chris661's Avatar
I've put some pictures up of my amplifier.
http://www.diyaudio.com/forums/galle...php/photo/5288
Chris
Old 2nd June 2010, 04:43 PM   #24
Cassiel is offline Cassiel  Libya
Hey, nice thread. This is my DIY Champ:
Old 2nd June 2010, 07:39 PM   #25
chris661's Avatar
Well thankyou for adding it here.
Perhaps the Mods just needed a reminder about it.
Old 7th September 2010, 04:14 PM   #26
TechnoBeaver is offline TechnoBeaver  Canada
Here is an update of my gear.
I installed a Celestion Vintage 30 in the lower sealed section and a Celestion "GreenBack" in the top semi open part.
Thats my '09 Gibson BFG Les Paul, I absolutely love this thing, practically plays itself.
I have some burlap to make a grill cloth for this, just got to get around to making a frame for it.
Old 7th September 2010, 04:16 PM   #27
Rock and Roll.
Old 26th September 2010, 07:18 PM   #28
Jarno is offline Jarno
A zebra and a P90 in that Les Paul? Great, with respect to a grille for your cabinet, what about this stuff:
By the way, I dropped off all my project parts for the five string shortscale at a local guitarbuilder, with this as a result:
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Plays like a dream, and sounds great. Still busy sorting out the final electronics though, proving a bit of a PITA (B1 buffer per pickup, filter per pickup, active mixing stage).
Oemptempa petoempetapap
Old 28th September 2010, 09:41 PM   #29
The Space Egg Corp is offline The Space Egg Corp  England
The Space Egg Corp's Avatar
Default Envelope Shaper ?
Originally Posted by vielle568 View Post
I have just finished building an electric vielle. The keyboard uses strings and a humbucker pick-up like an electric guitar but the rhythm is generated from an IR laser system that monitors the wheel speed. The drones come from a synthesizer module inside the instrument's body with the other electronics. All the sounds and effects can be regulated and mixed before output to a power amp. It works fine but I really need an ADSR envelope module to shape the rhythm pulses. Does anyone have knowledge of a simple circuit that works off a 9V supply that would do the trick? All I can find are schematics for synthesizers and they use +/- 18V which is OK if you have access to a transformer. My vielle is portable and uses batteries; consumation has to be at a minimum.
Thanks for any help.
Vielle568
Hi Vielle
Your instrument looks real cool.
Not sure why I'm posting the Boss Slow Gear, but
The SG-1 has become a cult and highly collectable item (hence the $475 tag for a 2nd hand one).
It is an envelope shaper of sorts, check the net for what people think of it, it's a bit different.
There are clones of the SG-1 about (see PDF, the 3rd thumbnail, I changed the file extension to .ZIP to allow it to be uploaded, as it's quite big. If you want to look at it just change the file extension back to .PDF and open with Adobe reader as normal !).
Also check out diystompboxes.com as most of the stuff there is powered by 9 volts.
Cheers Simon...
File Type: jpg Cult Boss Slow-Gear SG-1 bit expensive nowdays.jpg (88.1 KB, 377 views)
File Type: zip (Boss Slow-Gear Clone)swellinstructions.zip (579.1 KB, 22 views)
Old 30th September 2010, 03:48 PM   #30
475usd?!?!? And I thought the Spectrum was rare/expensive/overpriced:eBay link
that slow gear is something I'd like to build at one time, too many projects though (Meatball, Catalinbread SFT, the list goes on....).
Post your DIY Musical Instruments/Amps here!Hide this!Advertise here!
Signals from musical instruments in time domain PMA Everything Else 41 27th November 2007 09:31 AM
Aussie musical instruments technology - the didgeridoo jackinnj Instruments and Amps 0 12th July 2005 01:35 AM
ICE/ class d amps used for PA/musical instruments? knutinh Class D 76 24th March 2005 04:49 PM
Musical instruments and equipment one_happy_hippy Swap Meet 0 10th August 2004 04:21 PM
Call for Musical Instruments forum board bob4 Instruments and Amps 41 22nd November 2002 09:36 PM
Copyright ©1999-2019 diyAudio
