Instruments and Amps Everything that makes music, Especially including instrument amps.
Post your DIY Musical Instruments/Amps here!
Old 12th April 2010, 11:49 AM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Great thread
I have just ordered a Moses carbon bass neck, 4string 30" scale pictures will come
sometimes we know very little, and sometimes we know too much
Old 12th April 2010, 12:28 PM   #12
phase_accurate is online now phase_accurate
How are you going to tune this - ADGC or EADG ?
Charles
Old 12th April 2010, 04:25 PM   #13
bob91343 is offline bob91343  United States
Chris, the box and woofer were one, called a bass speaker. I installed a tweeter from a keyboard amplifier, and the amplifier is 30 Watts, from the same keyboard amplifier.
Later I took the remains of that keyboard amplifier, installed an old Lafayette home stereo amplifier, modified with op amps to give me gain and inversion, and now have a great little 25 Watt guitar amplifier with the speaker bridged between the two 8 Watt channels.
Old 12th April 2010, 10:20 PM   #14
Minion is offline Minion  Canada
Originally Posted by chris661 View Post
Wow! I want one of those!
Chris
Thanx !!!
If You listened to this amp you would definately want one , everyone would want one , it sounds freaking awesome , Somewhere between a Marshal and a Mesa dual rec but with way more gain and tonal options .....
Cheers
Old 12th April 2010, 10:46 PM   #15
Charles
Im not experienced, just normal EADG, I guess
But I think I know what you are getting at, that some say the short scale is a bit "soft" or mellow
I hope to get more time to build a complete 30" scale 6string
My plan is to make both work with the better full scale strings, thats the trick
Old 13th April 2010, 07:30 AM   #16
chris661 is offline chris661  United Kingdom
chris661's Avatar
Brilliant example of people using what they have to make something better. I admire that.
Cal, thanks for sticky-ing this. Hopefully, we'll get the 200 pages the rest of them have.
tinitus - at first I thought you meant a carbon fibre neck, which would have been pretty cool. I expect you'll work wonders with it.
I'm getting a new mains transformer for my amp today. After poking around with a scope, it was discovered that bigger transistors (of correct specs, of course), and a bigger PSU would greatly help to get some decent volume out.
My work: www.grimshawaudio.com
Old 13th April 2010, 10:13 AM   #17
Jarno is offline Jarno
Originally Posted by tinitus View Post
Great thread
That's cool! The Stanley Clarke copy I'm building will be 5 string 30" (well just over thirty, by sawing the first couple of frets off a 34" fingerboard). Didn't know Moses made short scale necks as well.
The trick is to use thicker strings with shorter scale lenghts, my humble Squier Bronco sounds great (despite also being 30" or 32", don't remember), put a decent pickup in there and there's no reason shorter scalelengths should sound worse.
Oemptempa petoempetapap
Old 13th April 2010, 02:44 PM   #18
Hopefully Its not insulting saying that its not that simple
If you shorten a 34" scale neck its still 34", just with a longer body
The shorter scale means less distance bewteen the frets, thats all
Or maybe I have misunderstood, and you have just expressed it wrong by saying "sawing off frets" ?
Maybe you mean shortening a "RAW" 34" fretboard ?
btw, I know a couple of fret position calculaters
Old 14th April 2010, 02:27 AM   #19
Ouch
Sorry Jarno, I read wrong
Sawing off the FIRST couple of frets does seem to work
I tried to calculate scale length, and it seem to ad up very nicely with a 30.3" scale
To those who doesnt know, it refers to FREE swinging string length
Thanks Jarno, thats quite cool, I didnt know that would work
Old 23rd April 2010, 07:27 PM   #20
vielle568 is offline vielle568  France
vielle568's Avatar
I have just finished building an electric vielle. The keyboard uses strings and a humbucker pick-up like an electric guitar but the rhythm is generated from an IR laser system that monitors the wheel speed. The drones come from a synthesizer module inside the instrument's body with the other electronics. All the sounds and effects can be regulated and mixed before output to a power amp. It works fine but I really need an ADSR envelope module to shape the rhythm pulses. Does anyone have knowledge of a simple circuit that works off a 9V supply that would do the trick? All I can find are schematics for synthesizers and they use +/- 18V which is OK if you have access to a transformer. My vielle is portable and uses batteries; consumation has to be at a minimum.
Thanks for any help.
Vielle568
Post your DIY Musical Instruments/Amps here!Hide this!Advertise here!
Signals from musical instruments in time domain PMA Everything Else 41 27th November 2007 09:31 AM
Aussie musical instruments technology - the didgeridoo jackinnj Instruments and Amps 0 12th July 2005 01:35 AM
ICE/ class d amps used for PA/musical instruments? knutinh Class D 76 24th March 2005 04:49 PM
Musical instruments and equipment one_happy_hippy Swap Meet 0 10th August 2004 04:21 PM
Call for Musical Instruments forum board bob4 Instruments and Amps 41 22nd November 2002 09:36 PM
Copyright ©1999-2019 diyAudio
