Go Back   Home > Forums > > >
Holton Precision Audio High quality, high performance amplifier modules and accessories
Old 16th September 2019, 04:38 AM   #181
The Saint is offline The Saint  Australia
The Saint's Avatar
Originally Posted by floatingkiwi View Post
From the looks of the photos the HPA-NXL300 R4 and the HPA-NXL500 R4 both use the same Exicon devices?
Hi floatingkiwi
Thanks for your interest in the Holton Audio amp modules.
You are correct both the NXL300 and the NXL500 use the same single die output devices, just more of them with the NXL500.
Personally I would not describe either of these modules as having bad bass response, in fact quite the opposite.
Cheers Anthony
holtonprecisionaudio.com
Old 16th September 2019, 09:01 AM   #182
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
My Holton amp builds.
I made 2 stereo amplifiers Nxl 300 for a friend with Dual die. Single Die is something new. I made Nxl 500 with Single die and nobody want it.
Old 16th September 2019, 09:04 AM   #183
Leeuwarden is offline Leeuwarden  Netherlands
Was the NXL500r4 ever sold with single die? How to recognize? I still have a pair NXL500r4 waiting to be exchanged with my NXV500R2 modules.
Old 16th September 2019, 09:40 AM   #184
The Saint's Avatar
The 500R2 modules used the now discontinued Toshiba VFETs
The NXL500 R4 modules use the Exicon Single Die Lateral MOSFETs
The R2 modules did have a tighter bass, most likely due to the Toshiba FETs.
The new NXL1000 amp module however fixes this apparent short coming
with a fast MOSFET Driver stage, which controls the output lateral MOSFETs with an iron grip!
Cheers Anthony
Old 16th September 2019, 10:10 AM   #185
Thanks Anthony but the new NXL 1000 will not be for Diy?
Old 16th September 2019, 10:12 AM   #186
The Saint's Avatar
If you want it; It can be available to a select few?
Cheers Anthony
Old 17th September 2019, 12:54 AM   #187
floatingkiwi is offline floatingkiwi  New Zealand
Send a message via Yahoo to floatingkiwi
Hi floatingkiwi
I wouldn't describe my NXL200R4 build lacking in bass either, especially now I can hear it with the clarity of a pair of 804 D3's. It seems tight to me.
I was trying to get some clarity from Erlend Sæterdal regarding his "bad bass" statement.
**Arcam DV139 - Marantz CD67SE - Parasound 2100 Preamp - Denon AVR4520 - B&W 804D3, CM C2, DS6S3 - REL Storm 5 - VDH Silver Jubilee Hybrid IC - Tara labs Prism Onmi bi-wire SC - Isol-8 Minisub2**
Old 17th September 2019, 03:35 PM   #188
I have closed system with low Q bass and low resistance coil. A boom boom basreflex system will off course play different.
Old 18th September 2019, 10:11 PM   #189
What, like a Bose?? who has those...
Old 19th September 2019, 12:00 AM   #190
Duelund modified Coral 12" in 140 l enclosure and near front wall.
My Holton amp builds.Hide this!Advertise here!
SSLV1.1 builds & fairy tales Salas Power Supplies 4215 16th March 2019 11:48 PM
Call for MyRef-C Builds & Photos bcmbob Chipamp 0 1st October 2010 11:57 PM
400 watt Holton amp upgrade Mattyo5 Solid State 31 19th June 2003 05:05 PM
Holton N-Channel Amp markkanof Solid State 1 17th June 2002 09:49 AM
Zen Revisited Vs Anthony Holton A/B amp FullThrottleRic Pass Labs 20 27th May 2001 02:29 PM
Copyright ©1999-2019 diyAudio
