Go Back   Home > Forums > > >
Holton Precision Audio High quality, high performance amplifier modules and accessories
Old 6th December 2011, 02:13 PM   #1
dvb projekt is online now dvb projekt  Germany
dvb projekt's Avatar
nxV recommendation for Magnepan MG 3.7
Default nxV recommendation for Magnepan MG 3.7
Hello Anthony,
could you recommend (sound quality 1st!) one of your mono nxV modules
for the Magnepan MG 3.7 ?
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
Best regards,
Oliver
F5 - SSLV 1.3 Ultra BiB
Old 6th December 2011, 07:24 PM   #2
The Saint is offline The Saint  Australia
The Saint's Avatar
Originally Posted by dvb-projekt View Post
Hello Anthony,
Best regards,
Oliver
Hello Oliver
To drive the magnepan I would recommend the nxV500 module or the nxV300
for best sound quality.
I hope this helps Oliver.
Kind regards
Anthony
Old 7th December 2011, 05:25 AM   #3
Hello Anthony,
next saturday i go to my Magnepan dealer and make a listening session...
Let's see if they could beat my Duo Omega horns...
If so, i must also change my 300B mono's to a new SS amp
Best regards,
Oliver
Old 7th December 2011, 10:36 AM   #4
The Saint's Avatar
Hello Anthony,
Best regards,
Oliver
I will look forward to hearing how it you went.
Old 7th December 2011, 10:47 AM   #5
I will report back
BTW, how much current max. needs the nxV500 form the PSU?
Just for calculating...
Best regards,
Oliver
Old 7th December 2011, 10:50 AM   #6
The Saint's Avatar
I will report back
Best regards,
Oliver
send me an email and I will email you back the nxv500 installation manual.
aussieamps@gmail.com
Cheers
Anthony
Old 17th December 2011, 03:17 PM   #7
la1209 is offline la1209  Hong Kong
I'm now using nxV500 to drive my MG12.
My power amplifier based on nxV500 just finished a few hours before, I will post some pics here later.
Thanks Anthony, you did a good job, the modules performance is very very good! Relax but no lost of details, especially the silkly high-freq, no harsh, very smooth, pin point focus, wide open sound with very good resolution!
Kenneth Lau
Old 17th December 2011, 10:14 PM   #8
The Saint's Avatar
Kenneth Lau
Thanks Kenneth
I am very happy you like the nxV500 sound and build quality.
I look forward to seeing some of your photos of your build.
Cheers
Anthony
Aussie Amplifiers
Old 18th December 2011, 03:08 AM   #9
My amplifier is built with a custom made heavy duty full aluminium chassis sized W430 H200 D412, two Nuvotem 625VA trans with 2*55V-0 secondary, dual mono configuration with one channel two Vishay BC 154 33000uF/100V capacitors, and a soft-start module is installed that designed by my friend in HK, no speaker protection broad install because I found that amplifier modules is very stable, so I haven't install it.
Old 18th December 2011, 03:54 AM   #10
The Saint's Avatar
Hi Kenneth
Your nxV500 amplifier looks awesome!
Well done on the construction.
Oliver how did you go with the MG speaker audition?
Anthony
Aussie Amplifiers
nxV recommendation for Magnepan MG 3.7Hide this!Advertise here!
Magnepan MG-12 Crossover upgrade waynebosz Planars & Exotics 45 27th July 2017 05:24 PM
Magnepan MG-2's glorocks Swap Meet 2 16th July 2007 11:25 PM
Magnepan MG 10/QR crossroads Swap Meet 0 2nd February 2007 05:10 AM
Zen 4 uses with Magnepan MG 12s Zapped Pass Labs 0 24th March 2003 10:56 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
