Headphone Systems Everything to do with Headphones
Current drive headphone amp in the works
Thread Tools
Old 10th November 2021, 11:36 PM   #21
abstract is offline abstract  Poland
I'm not too worried about EQ at the moment -- otherwise I'd never get it finished. I'm keeping my fingers crossed that they will be less sibilant.
New 10V virtual ground.
A lopsided 4:1 emitter resistor ratio seems to improve distortion a bit, probably because the control is also a bit lopsided.
Bias set to about 1.5mA (1k + POT4 = 2.2k).
1V sine through 125 ohms produced a +/-1.4uV sine offset with only 0.4% THD (referenced to H1 = 1.4uV).
(link to my blog: https://lechaudio.altervista.org/ )
Old 11th November 2021, 05:39 AM   #22
PRR is offline PRR  United States
PRR's Avatar
Because R61 POT4 are reducing the drive to Q12. Bypass cap? Diode bias? It really is another "output stage". (And really does double your losses.)
Old 11th November 2021, 07:10 AM   #23
At 1.4uV total including the fundamental vs 1,000,000uV signal level, I don't think it matters.
The simulator used a NE5534 model which might have slightly higher gain than the NE5532 that I actually want to use, but it's still nice and slow. I haven't checked the PSRR, but the 20V rail is already regulated.
I may change the pot to 2 parallel thin film resistors.
Old 24th November 2021, 12:29 PM   #24
The prototype PCB is now in production. Can't wait!
Too many cool things on it for something not to go wrong in the beginning, but we shall see.
I might re-purpose my post/s on the first page to add updates to keep things organised.
Recapping:
Topology:
Single Ended class-A.
First stage: open drain JFET with resistor pull-up and low-pass filtering of the +ve power supply rail.
2nd stage: open drain MOSFET with a 2-stage JFET+PNP constant current source. A 2-stage CCS seemed to give the best of both worlds with the JFET having good distortion matching and the superior ripple rejection of the PNP.
DC coupled:
Instead of a 470u-1000uF output capacitor, together with its self-defeating leakage current and DC offset, the design uses a virtual ground at around 10-12V (adjustable). Maximum simplicity with an NE5532 op-amp boosted with a push-pull PNP-NPN output stage. 1uV ripple vs 1V signal level should be inaudible.
Servo:
A subsonic filtered feedback amplifier (servo) compares the audio output against the virtual ground, and provides local feedback to the MOSFET. Apart from the servo, which has very low gain at audio frequencies, the design relies entirely on emitter degeneration.
It seems to have a lot of stuff for something that is basically:
INPUT-->capacitor-->JFET-->capacitor-->MOSFET --> headphone --> v.ground.
PSU
SMPS with 5V to 24V boost.
Instead of developing a dual PSU, where I would have to consider ripple on both rails, everything is ground referenced.
Anti-thump circuit:
An LPC804 microprocessor monitors voltage levels with resistor dividers and triggers a dual-coil relay. I specifically wanted to avoid wasting power with a "normally off" relay. And the logistics hot-unplugging is still a bit up in the air, but I don't want to do everything at once. The coils can be fired manually so I can start listening while still writing the firmware.
  Reply to this post
Current drive headphone amp in the worksHide this!Advertise here!
Thread Tools
mix current drive with voltage drive at LF? capslock Solid State 103 21st September 2021 01:45 PM
Low power current drive headphone amp design werediver Solid State 7 17th August 2020 10:52 AM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 05:31 PM
Just finished a new PP headphone amp - and it works !! Shoog Headphone Systems 22 28th October 2007 01:46 PM
what current production tweeter(s) works well with a 1st order crossover? Alex S Multi-Way 18 4th April 2006 07:33 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
