You do not need thik wires. 22AWG is fine.
You only need to go thicker if the wire is long and you want some stiffness.
Wire, PTFE Jacket, 22 AWG Stranded, Silver-Plated Copper, White
Gold plated 4mm banana is also perfect.
It is only a few mA afterall.
Patrick
Patrick
What's in the box?
Anybody can make this converter. Mine is based on Rod Elliot's Project 100:
Project 100
Project 100
For noephytes like me, below is an explanation of the issues with this amps and headphones
DIY Audio Electronics from Zynsonix.com: Speaker Amp to Headphone Cable
Sorry there's NO explanation there and only a sure-fire way to immediately blow up your headphones....
Here's some good explanations, too:
Power amp adapter | DIY-Audio-Heaven
