Headphone Systems Everything to do with Headphones
New Headphone Amplifier Design
Thread Tools
Old 16th October 2021, 01:33 PM   #41
hpasternack is offline hpasternack
Connecting the collectors this way maintains a nearly constant, low voltage from collector to emitter of of the driver transistors. They are effectively cascoded. This has several advantages:
- Lowers driver transistor power dissipation
- Eliminates nonlinearity caused by Early effect
- Eliminates nonlinearity caused by nonlinear junction capacitance
- Lowers driver transistor effective input and output capacitance
Since the output transistors now carry the driver bias current, I think this helps the output stage stay in Class A.
I'm not aware of any disadvantages, but that doesn't mean there aren't any. Let's see what people say in your thread.
Edit: This has been asked before. See here: Questions regarding diamond buffers.
The driver transistors run at nearly zero Vcb. You want devices with a low saturation voltage here.
Edit: TBH, I didn't think of this latter point when I selected the TTA/TTC004B drivers. Their saturation voltage is given as 1.3V which is inadequate in this design, oops. But they are medium power devices with a maximum collector current of 1.5A. Saturation voltage will be much lower at 10mA. It seems to work well, but maybe changing to BC550/560 would give better results. In that case, you need to find a way to mount the TO-92 devices to the heat sink for thermal tracking.
Old 16th October 2021, 02:05 PM   #42
SPICE predicts we have about 1.2V across the drivers, so we just get by by the skin of our teeth. Crisis averted, probably.
Edit: The plot of Vce sat versus Ic paints a more encouraging picture at low collector current.
  Reply to this post
New Headphone Amplifier DesignHide this!Advertise here!
Thread Tools
FS: The Wire headphone SE-SE headphone amplifier ulogin Swap Meet 67 11th September 2018 04:48 PM
FS: The Wire headphone SE-SE headphone amplifier ulogin Swap Meet 23 30th January 2018 09:01 PM
Headphone Impedance and headphone amplifier TheGimp Tubes / Valves 89 3rd May 2014 01:46 PM
Looking to hire someone to help with simple headphone amplifier design FasterHorses Chip Amps 4 17th May 2011 07:45 PM
My DIY headphone amplifier design cetoole Headphone Systems 26 9th December 2005 01:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
