Headphone Systems Everything to do with Headphones
Tube amp for power hungry planar magnetics
Thread Tools
Old 27th July 2021, 08:18 AM   #11
Benji90 is offline Benji90  Italy
Thanks!
I'm slightly changing the question.
What would be your opinion about a set (or pp) amplifier with output transformers using for example 300b or 2a3 or el84?
Old 27th July 2021, 11:12 AM   #12
Grumpish is offline Grumpish  United Kingdom
Originally Posted by Benji90 View Post
Thanks!
I use a Tubelab SE with 45 tubes and some custom made Toriody output transformers - it works really well with my Audeze LCD2's, although I did have to use a Neurochrome HV regulator to get rid of the last traces of hum. With 300b's it would probably even drive a pair of HiFiman HE6's
Old 28th July 2021, 07:50 PM   #13
HiGHFLYiN9s is offline HiGHFLYiN9s  United States
HiGHFLYiN9s's Avatar
The Audeze LCD line isn't too power hungry. The Bottlehead S.E.X. is a nice option if you want a kit. I liked the pairing. The WHAMMY is also a good option with very adequate output power.
As XKR wrote the HE-6 and HE-6se require a beefier output. Other offenders include the Susvara, HEDDPhones, and the Abyss 1266.
Originally Posted by xrk971 View Post
I am working with Jhofland and we developed a headphone amp with a SET tube buffer stage which then drives the solid state OPA451 to make about 5W into 32ohms. We have two versions, one is 2W and the other 5W. They look very similar as prototypes.
I'd be interested in learning more about this.
I'd reckon it would as well.
All of these options have been used for headphone amps. I believe Eddie Current did the 2a3, there are a handful of 300b headphone amps out there (Cayin, Elekit, Eddie Current, etc.), and AudioNoteKits offers an EL84 headphone amp (Manley too I believe). The tubes all sound different, so that would be the primary driving factor for choice IMHO. I'd personally like to see an EL34 headphone amp design as I'm fond of that tube's midrange.
My DIY Electronics Blog: DIYAudioBlog.com
  Reply to this post
Tube amp for power hungry planar magneticsHide this!Advertise here!
Thread Tools
Planar magnetics & ribbons fivestring Planars & Exotics 9 12th September 2008 04:36 PM
The most power hungry music? hairylee Music 10 24th January 2008 02:20 AM
Power hungry Zen v5 builders ingvar ahlberg Pass Labs 7 7th April 2004 10:34 PM
Planar Magnetics jwatts Planars & Exotics 2 26th March 2004 12:58 AM
Hungry of power? check this out martioz Solid State 15 1st March 2003 02:13 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
