Headphone Systems Everything to do with Headphones
X-Altra HPA-1 Class A Headphone Amplifier
Thread Tools
Old 9th April 2021, 03:21 PM   #61
passive420 is offline passive420  United Kingdom
Good quality solder makes a big difference. Kester solder is hard to beat, the best I have used is Cardas quad eutectic with Topnik RF800 liquid flux.
None of that lead free nonsense either
Metcal MX500 system is the finest kit available, keep an eye on the bay as they come up quite often.
Old 9th April 2021, 04:17 PM   #62
sonidos is offline sonidos  United States
Libertador de la Música
sonidos's Avatar
Thanks for the suggestions!
Old 9th April 2021, 04:53 PM   #63
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
I don’t use lead free for DIY. Lead free has higher melting temps and kills ultra-fine pencil tip bits on my Weller.
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 9th April 2021, 05:28 PM   #64
sonidos's Avatar
Someone commented the same in an Amazon review I read last night. I'll avoid lead-free going forward. I found some thin diameter Kester w/lead on Amazon, so I'm almost set to build.
Old 9th April 2021, 05:49 PM   #65
Kester is excellent, the 63/37 is all you need. Lovely stuff. Digikey and mouser sell it by the reel.
A good deal on a half reel of 63/37 -
Kester Solder Wire SN63PB37 24-6337-8800 729198854430 | eBay
Old 9th April 2021, 07:23 PM   #66
sonidos's Avatar
passive420, thanks. In the past, I went the other direction (lead free) and had total frustration so glad to get the recommendations from both of you that will make the building a pleasure rather than a total chore with damaged parts and solder globs.
Old 10th April 2021, 10:23 PM   #67
kn0ppers is offline kn0ppers  Germany
The one passive420 linked is 0.8mm diameter (at least the picture looks like it says 0.8mm on the roll). For 0805 I personally find 0.5mm to be more suitable. You feed slightly more solder wire and thus have more control over how much solder flows into the joint (so you can more easily get a good joint geometry).
Old 10th April 2021, 10:49 PM   #68
You're right sorry, didn't check the diameter. 0.5 would be better for smaller work. For anything else you will burn through a reel in a year.
Not to be too pedantic: you do not really 'feed' any solder when hand soldering SMD parts? With the part held in place, you tap the solder with the iron bit and transfer to the fluxed joint. With the right geometry bit a tiny blob can be controlled nicely.
Just checked my Cardas solder and it's 0.86mm, been using it for 6 years. It's more than fine, good solder and kit is the key to success.
That Kester is beautiful stuff to use, with RF800 flux and Citrus based cleaner you'll be producing your best work.
Old 10th April 2021, 11:08 PM   #69
Sorry off topic: I won't lie - I'm very proud of my soldering skills, OCD has it's advantages. I'll take a long time to place a component perfectly. Line them up like soldiers or don't bother...
Some of my best work, Sjostrom diamond buffers and EUVL's SHPP board, two of the more challenging builds in DIY audio !
I bloody love SMD projects.
Edit: Good vision helps, being able to see the little f**k**s helps immensely, these proved worth the money -
Headband Magnifier Glasses with 2 LED Lights and 5 Detachable Lenses 1X,1.5X,2X,2.5X,3.5X-USB Charging Hands Free Magnifying Glass for Close Work,Jewelry Work,Watch Repair,Crafts: Amazon.co.uk: Office Products
Old 10th April 2021, 11:46 PM   #70
Bonsai's Avatar
Nice work!!! I love SMD as well
X-Altra HPA-1 Class A Headphone AmplifierHide this!Advertise here!
Thread Tools
Bonsai’s X-Altra MC/MM Phono Preamp al2002 Analogue Source 121 6th May 2021 06:51 PM
HPA-1 Class A Headphone Amplifier Bonsai Headphone Systems 18 12th August 2020 08:28 AM
HPA-nxV300 & HPA-nxV300se what's the difference? pcsl999 Holton Precision Audio 14 3rd September 2013 10:24 PM
X-Altra Mini LM4562 based Pre-Amp Bonsai Chip Amps 4 15th November 2010 04:12 PM
X-Altra Mini One Bonsai Analog Line Level 8 24th October 2010 10:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
