Headphone Systems Everything to do with Headphones
X-Altra HPA-1 Class A Headphone Amplifier
Thread Tools
Old 10th October 2021, 08:30 PM   #181
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
OK, thanks. I'll take a good look at that gun.
Jan
Old 11th October 2021, 04:59 AM   #182
wirewiggler is offline wirewiggler  United States
Andrew,
So my output voltage is +- 16.7 V should I go with 100 ohms for R6-R7 R8-R9 instead of 120 ohms. This is why my mute function is not working. I have 75 ohm on hand.
Thanks Bill
Old 11th October 2021, 07:17 AM   #183
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
Bill, you need to go UP in value for those. Try 180 to 270 Ohms.
Sorry, I have an aversion to pots! Anywhere above 17.5 volts will work but don’t go more than a 100 -200 mV over 18 V because the opamps have max ratings at +-18V
(Other option is to solder a 500 ohm to 2 k pot in place of the resistors, adjust the O/P voltage and then measure the pot and replace with fixed resistors)
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 11th October 2021, 07:22 AM   #184
Bonsai's Avatar
Looks like a nice soldering station. I wave a Weller and might go for this when it packs up (6 yrs old now). They are retailing for £92 here in the UK on Amazon.
Old 11th October 2021, 02:55 PM   #185
The soldering iron has more heat then my Weller, I was having trouble soldering ground planes on 2oz copper boards. The hot air gun is handy for other things as well, preheating large boards ,and heat-shrink tubing. This despiser is handy for getting the solder on the boards. When you pre heat the board then you don’t have a problem getting the solder off the tip. Dispenser is JBC tools dpm-a.
Bill
File Type: jpg D017948B-2659-4736-8792-FBEEF1979D35.jpg (851.9 KB, 105 views)
Old 11th October 2021, 06:22 PM   #186
Bonsai's Avatar
Bill, I assume you are using solder paste? Never tried the hot airgun method but I think it will produce the best looking SMD boards.
I'm very pleased I transitioned to SMD - seriously good way to build stuff as long as you keep it to 0805 and above, SOT23 and bigger and TSSOP with 1mm lead spacing or better.
Old 12th October 2021, 04:02 PM   #187
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Try these tapered plastic “Henna” tips. The 22ga is perfect for use with that dispenser tool and because the tip is flexible, a slight push pinches off the paste to allow neat dispensing. You don’t want to dispense on a warm board as it flows all over and makes a mess before you can place the components. This tip is very precise and lets you easily make 0603 dots or even tiny 0.5mm wide pads on some of the smaller components.
Glue Henna Dispensing Needle Tips Luer Lock Blunt End Plastic Tapered Needles 22 Gauge 100 Pieces https://www.amazon.com/dp/B07GLJZWL8...4PK2E4BX384S2P
XRKaudio Store // Manufacturerís Forum
Old 12th October 2021, 09:02 PM   #188
Bonsai's Avatar
Thanks X - I'll give that a try!
Old 14th October 2021, 02:03 PM   #189
Thanks X ,
yep if you heat the boards up too much the solder does turn to liquid, and if there is a via on the pad it runs through it. My hot plate has temp regulation so I turned it down to 95 degrees and the solder did not liquify but came off the tip. I do have a problem with it continuing to leak out when I set the dispenser down, maybe the tips will help. All in all I feel I will be able to continue with diy and smt parts.
Bill
Old 14th October 2021, 03:08 PM   #190
stefan66 is offline stefan66
I'm going to build this maybe next year in May if things are good, along with some diy "grado" clones, their impedance is rated at 32ohms, will the amp be sufficient?
Another question Andrew, I didn't see the part no. for the heatsink in the BOM, could you elaborate on what they are? Or the dimensions would do.
Last question what is the approximate cost of the components? I just want a vague idea. Thanks.
X-Altra HPA-1 Class A Headphone AmplifierHide this!Advertise here!
Thread Tools
Bonsaiís X-Altra MC/MM Phono Preamp al2002 Analogue Source 270 Yesterday 01:45 PM
HPA-1 Class A Headphone Amplifier Bonsai Headphone Systems 18 12th August 2020 08:28 AM
HPA-nxV300 & HPA-nxV300se what's the difference? pcsl999 Holton Precision Audio 14 3rd September 2013 10:24 PM
X-Altra Mini LM4562 based Pre-Amp Bonsai Chip Amps 4 15th November 2010 04:12 PM
X-Altra Mini One Bonsai Analog Line Level 8 24th October 2010 10:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
