Headphone Systems Everything to do with Headphones
X-Altra HPA-1 Class A Headphone Amplifier
Thread Tools
Old 17th June 2021, 06:21 AM   #141
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
This depends on how efficient the headphones are. The HPA-1 will drive 16 Ohms - it current limits at about 250-300 mA output. If you phones are efficient then they will be load enough well before this point, otherwise not.
I would try it, and if you’re not happy, then build a second amp.
Bonsai X-Altra MC/MM preamp http://hifisonix.com/x-altra-phono-eq-preamp/ Ground Loops http://hifisonix.com/ground-loops/
Old 23rd June 2021, 09:02 AM   #142
Mooly's Avatar
@LarsLWO Why are you posting under two identities within this thread?
Old 23rd June 2021, 12:49 PM   #143
LarsLWO is offline LarsLWO
IĎm not. IĎm working together with my roommate. IsnĎt that okay?
Old 23rd June 2021, 12:56 PM   #144
Mooly's Avatar
That is OK but I hope you understand why we have to ask.
Old 2nd July 2021, 07:37 PM   #145
Vrystaat is offline Vrystaat  South Africa
Andrew, thanks a lot,it is much appreciated ! I have received the board today. Just to good to be true with this Post Office in this broken place.
Now to order those minute nipper components !
Jan
Old 3rd July 2021, 05:46 AM   #146
jaycee is offline jaycee  United Kingdom
An interesting design Bonsai. I'll play with it in LTSpice, and then I might build this into my own DAC rather than the simple diamond buffer I was planning to add
Old 3rd July 2021, 07:37 AM   #147
kaliwraith is offline kaliwraith
Bonsai, can you combine shipping on the headphone amp and phono preamp?
Old 3rd July 2021, 11:04 AM   #148
Bonsai's Avatar
Yes, anything you want.
I have a power supply board coming for the headphone amp (it’s also for the coming line level pre). It’s about 2 weeks away if you want to wait for that as well.
Old 3rd July 2021, 11:05 AM   #149
Bonsai's Avatar
thatís great!
Old 3rd July 2021, 11:14 PM   #150
I have a power supply board coming for the headphone amp (itís also for the coming line level pre). Itís about 2 weeks away if you want to wait for that as well.
Very cool. Yeah waiting is no problem. I am very slow to complete projects...
X-Altra HPA-1 Class A Headphone AmplifierHide this!Advertise here!
Thread Tools
Bonsaiís X-Altra MC/MM Phono Preamp al2002 Analogue Source 201 21st July 2021 08:27 PM
HPA-1 Class A Headphone Amplifier Bonsai Headphone Systems 18 12th August 2020 08:28 AM
HPA-nxV300 & HPA-nxV300se what's the difference? pcsl999 Holton Precision Audio 14 3rd September 2013 10:24 PM
X-Altra Mini LM4562 based Pre-Amp Bonsai Chip Amps 4 15th November 2010 04:12 PM
X-Altra Mini One Bonsai Analog Line Level 8 24th October 2010 10:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
