Headphone Systems Everything to do with Headphones
DAC/Headphone Amp Design
Thread Tools
Old 20th January 2021, 02:43 AM   #11
tomchr is online now tomchr  Canada
tomchr's Avatar
This provides some good guidance on grounding in mixed-signal systems.
https://www.teledyne-e2v.com/content...ard-Layout.pdf
Tom
Modulus-86, 186, 286, & 686: 40-240W (8Ω), <-120dB THD. HP-2 Headphone Amp: 660mW, <-130dB THD. Taming the LM3886.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 22nd January 2021, 12:12 AM   #12
Kdent is offline Kdent  United States
I truly appreciate the responses everyone!
Planning on actually getting these soldered professionally as I have a company in mind that is currently offering discounted rates. If the price is reasonable then that will be the play, if not then I might make some modifications per Tom’s suggestions and set up a small oven
Kaden
Old 22nd January 2021, 04:29 PM   #13
kn0ppers is offline kn0ppers  Germany
I wouldn't really suggest having a first revision PCB assembled. You don't know for sure if everything will be working as expected and if changes to the circuit or layout might be required. However, if you choose to have it assembled, there are some things to keep in mind for SMD reflow assembly. You probably know this already but it can't hurt:
1. You should know the solder paste thickness the assembly house uses and adjust the footprint of parts with thermal pads accordingly, same thing if you use a stencil and reflow it yourself. It depends on the package how critical this actually is, but if something goes wrong here and you don't have a hot-air station, it is pretty much impossible to fix. The manufacturer will usually tell you about this towards the end of the datasheet if it applies (I think TI usually does so next to the technical drawing of the footprint).
2. You might want to take precautions to avoid tombstoning, especially when SMD capacitors or resistors are connected to say a ground plane/pour on one of their terminals and to a thin signal line on the other. Not a big deal to fix this if it happens, but it's kind of annoying and mostly avoidable as well.
  Reply to this post
DAC/Headphone Amp DesignHide this!Advertise here!
Thread Tools
A supper dac & headphone amp with ES9038pro op111op Headphone Systems 17 6th March 2018 08:41 PM
USB DAC & headphone Amp with 3D Printed Enclosure Big Gig Headphone Systems 29 6th March 2013 11:10 PM
headphone amps vs headphone inputs? awangotango Headphone Systems 7 13th October 2012 02:36 AM
HLLY HIGH END DMK-IV USB DAC Headphone AMP Pre-AMP hllyelec Vendor's Bazaar 19 4th January 2010 02:10 AM
LM3875 Amp/ Headphone Amp and USB DAC edpgc Headphone Systems 19 14th April 2004 05:09 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
