Btw, are you done with your build?
Not yet.
This pandemic turned my whole program upside down at work.
Thank you Bogdan for your valuable informations.
It is rare to see an amplifier with a flat open loop gain of up to 20 kHz. This prelude to an excellent sound and sound stage of great naturalness and precision, as advocated by John Curl in his various articles. With regard to balanced output, I did not mean a real balanced amplifier with two identical amplifiers per channel but an output with separate grounds (4 pins),which can be obtained with two separate circuits starting from the rectifiers of the power supply. (two amplifiers and two +/- Vcc power supplies) This is preferred by many people to the traditional solution with common ground output due to increased headphone driver control, better low frequency control and separation.
Thank you again and congratulations for the excellent realization.
Semola
Semola
Semola
You won't know exactly until you listen to him. Probably if an audio guru says something, it MUST be exactly ...
Semola
Possibly, but I'm not convinced ...
You have time to become one.
Maybe is time for something fresh, "The cult of 2nd cycle distortion"
I want to order a pcb( five or ten pcs.) for my version without SMD components except for those that are.
The price per pcb is 8.5 EUR (shipping not included).Who is interested send me an email at knauf1919 @ gmail dot com.
- Headphone Systems
- VEIL SE Line / Headphone CFB amplifier
