Headphone Systems Everything to do with Headphones
Designing my headphone amp
Thread Tools
Old 13th July 2021, 11:05 AM   #151
dreamth is offline dreamth  Romania
welll this is your 7th month in this project...
Old 13th July 2021, 11:22 AM   #152
NickKUK is offline NickKUK  United Kingdom
The amp is for me - learnt every day (also covid and work has got in the way)
Old 13th July 2021, 04:23 PM   #153
So this is doing B+/B- 320V at 250mA.
I'll check with the PSU folks if there's any issues in connecting like this.
Old 14th July 2021, 01:26 AM   #154
thuanth43 is offline thuanth43  Singapore
Could that psu go up to 400v? Would be a good supply for electrostatic headphone amp.
Old 14th July 2021, 01:59 AM   #155
The concept - yes.
The main thing I need to check is ensuring equal voltages on start up and shutdown.
Old 24th July 2021, 05:48 PM   #156
So after all the consideration for layout.. note the edge of the red is the centre... not the middle!
I'll sort out the mounting holes tomorrow and then I can start really putting stuff inside.
I decided to move the driver tube into the centre.. no real issue with the implementation, but solves that 'missing hole' feel.
Old 25th July 2021, 04:11 PM   #157
Hacking away at the prototyping case..
All the V1 sockets attached - I can now start really installing bits inside..
I will have to get myself a few more tubes... In the original single ended configuration..
However this is what V1 will look like.
The pond project is the first priority, this is second but we're getting there..
I found my yellow/green solid wire is 1.3mm diameter.. so way thick enough for heater wire Plan is now that yellow/green twisted is heaters rather than using brown.
Old 25th July 2021, 04:39 PM   #158
The cap layout will be something like this:
Old 1st August 2021, 12:32 PM   #159
Just been sorting out the power transformers and inductors.
Unfortunately Terry (Cantebury Windings) isn't taking on new work for 2 months.
I thought about Toroidy in Poland but they have a comment on their website for longer delays for orders given the current copper issues.
So I had a chat with Stephen at Tiger Transformers today. This looks very promising. I've also over specced the transformers to allow me to use them for other project prototypes (ie the RF tube digital amp).
These will be wound on over sized cores, with insulation and banding, but I will have two separate transformers for the B+ (each having two isolated secondaries to work with the regulators).
He also had a good solution for the heater supplies too and I should find out about the 9H chokes later this week.
They're custom but they don't break the bank. I'll confirm everything later this week and then put an order in.
Old 11th August 2021, 08:09 AM   #160
I've been having a listen to one of the output pair capacitor blocks, directly from the CD player. Some noticeable points:
1. The CD player line-level is starting to find it hard to drive, leading to some additional distortion. I don't have a resistor or volume thus the CD player is seeing through the 4x330uF+0.22uF the low impedance not the high impedance input stage of the next section as it would have been designed for.
2. The sound is fast and has punch/slam in the deep bass however give point 1 it's not as clear as I'm expecting the final amp to be (with 4 of these sections per channel, each being driven separately).
As the pond is pending a few bits, I currently have some time, so I may knock up the remaining modules. So I may have chance to finish the transformer modelling.
Also I decided I would go with point to point rather than use a PCB board. Probably not the long term solution but I decided to point-to-point everything for this amp.
V1 - low gain tube HPA OTL, fully balanced cascode 12BH7A, 12BH7A CCS, 12BH7A drivers and ECC99-BJT hybrid circlotron. (build)
V2 - pure digital tube HPA, RF-tube DSD512 modulation with mosfet output stage. (initial design)
Designing my headphone ampHide this!Advertise here!
Thread Tools
I'm designing a TPA6120 based headphone amp, is there anyone can give me some advice shadownee Headphone Systems 13 31st August 2012 04:50 AM
C&C request: designing a headphone amp Thalyn Chip Amps 0 14th April 2012 12:12 PM
Designing a super low distortion headphone amp. Rainwulf Chip Amps 41 1st April 2011 12:24 AM
designing horn for compression driver & tweeters jayam000 Multi-Way 0 15th April 2009 09:26 AM
Designing for guys who like designing Sch3mat1c Tubes / Valves 14 31st August 2003 11:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
