Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Headphone Systems Everything to do with Headphones |
Thread Tools |
#11 |
The plate is 280ohm, with two tubes in push-pull 140ohm before feedback.
One option was/is to use a NPN/PNP to follow each output tube and possibly additional tubes - the net effect would be to lower the impedance further. The simulations are coming along nicely. The current working version is a 6SN7 as a differential amp with a 6AS7 in push-pull and a DC servo on the 6AS7 grid bias. This is actually operating in Class A at the moment. With feedback I still think it would have enough power for average listening without adding an additional stage. The second simulation I have a driver stage between the two - typically this can really only be used with feedback or causes overdrive distortion by soft clipping without the gain change using global negative feedback. I could make it 1:1 if feedback not used but then it would simply add noise. This was just a second of simulation with NFB so the FFT hasn't had chance to really drop the noise floor - typically I'd run 5 minutes of simulation time without the first 30 seconds but it's very slow: Screenshot 2020-12-02 at 11.21.53.png Last edited by NickKUK; 3rd December 2020 at 09:54 AM. |
#12 |
You need a better window function there... got Kaiser-Bessel? In LTspice I generally let transient sim run for 20 cycles or so.
Note that K240S' are notorious for being sensitive to output impedance... you really want <10 ohms. If you must go OTL by all means (silly and wasteful as it is... tubes just don't work well at the voltage/impedance levels you need for a headphone amp), I'd recommend near Bruno Putzeys levels of feedback. |
#13 |
Yup, no window applied.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
DIY amplifier performance checking - step by step | Dunk02 | Equipment & Tools | 21 | 7th July 2018 08:31 PM |
when checking op amp parts??? | Eaudio2013 | Car Audio | 4 | 10th December 2017 12:18 AM |
Guitar Tube Amp - Double Checking Choice of Power Transformer | steeledriver | Instruments and Amps | 44 | 23rd July 2015 05:41 PM |
checking calculations | mountainhick | Multi-Way | 3 | 20th January 2010 12:27 AM |
Headphone amp with OPA561. Any thoughts? | Rookie | Headphone Systems | 5 | 23rd December 2003 05:48 PM |
New To Site? | Need Help? |
