Headphone Systems Everything to do with Headphones
My DIY BT5.0 headphone amplifier
Old 6th August 2020, 06:44 PM   #51
iamwhoiam is offline iamwhoiam  United Kingdom
iamwhoiam's Avatar
Originally Posted by chunyan0001 View Post
I love the battery level meter animated shown when power on.
Battery voltage meter - YouTube
Love this detail. You didn't have to do this, but you did
Old 7th August 2020, 11:19 AM   #52
chunyan0001 is offline chunyan0001  Taiwan
You know me haha.
Just got battery auto learning machine yesterday.
Start learning 1.5A(25W) discharge cauve.
Full cycle learning will take 18 hours.
Old 7th August 2020, 02:45 PM   #53
Change platform to run 25w constant power discharge test
Old 7th August 2020, 05:14 PM   #54
iamwhoiam's Avatar
Is this conditioning the battery? I didn't realise batteries had to "learn" their current draws?
Old 8th August 2020, 01:04 AM   #55
All the Consumer product like smart phone / Notebook / Tablet
we use Multiple cell in Series together to creat high voltage (for lower operating current)
Lower current mean lower Power loss.
and Multiple cells in parallel together to creat high capacity
But because of the difference in battery internal resistance.
The battery protection / Gauge Ic need to Forecast discharge curve and Computing capacity
So we call this "Charge/discharge process" = "learning process"
And call the "Charge/discharge machine" = " Learning machine"
You can setup different discharge current and discharge the cell.
Then the Battery Gauge IC can record this curve in EEPROM
after learning process
It make Battery Gauge IC can Accurately predict battery capacity.
Old 8th August 2020, 01:05 AM   #56
10 hours discharge curve
Old 8th August 2020, 01:07 AM   #57
It will run out of battery power after 4 hours
Old 8th August 2020, 05:34 AM   #58
Test completed
Got the 25W discharge curve
Now I can modify the battery level LED to fit this discharge curve
Old 8th August 2020, 06:23 AM   #59
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi Murasame Yui, did you ever test the device without batteries so mains operated? How did it perform?
It's only audio. Member of the non modular PCB design committee
Old 8th August 2020, 06:51 AM   #60
I will do the test by use AP525 after aluminum case complete.
Also this amplifier can not be use without battery.
My DIY BT5.0 headphone amplifierHide this!Advertise here!
FS: The Wire headphone SE-SE headphone amplifier ulogin Swap Meet 67 11th September 2018 04:48 PM
FS: The Wire headphone SE-SE headphone amplifier ulogin Swap Meet 23 30th January 2018 09:01 PM
X5 headphone Amplifier Algar_emi Headphone Systems 10 18th December 2016 04:51 PM
C3g Headphone amplifier neskor Swap Meet 1 30th June 2014 03:18 PM
Headphone Impedance and headphone amplifier TheGimp Tubes / Valves 89 3rd May 2014 01:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
