Headphone Systems Everything to do with Headphones
Sennheiser HD650 driven by class a amplifer?
Old 12th March 2020, 02:10 AM   #1
gadut is offline gadut  Indonesia
gadut's Avatar
Default Sennheiser HD650 driven by class a amplifer?
I have been using my HD650 for a year at my office using headamp design based on opamp. if i recall my memory, i thought that i read somewhere that someone plug HD650 to class a amplifier F2J and other user connected it to 300B
i am always tempted to plug my cans to either J2/M2/SIT L'amp that i have but worried if i burn the voice coil
any advice to protect my cans? maybe adding parallel high power resistor?
thanks
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 12th March 2020, 03:12 AM   #2
rayma is offline rayma  United States
I'd worry more about your ears, since they will produce 115dB with only 1V input.
Any headphone can be damaged, but a parallel resistor won't help.
A coupling capacitor (50uF bipolar) will protect from DC due to amplifier failure.
Old 12th March 2020, 03:18 AM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Ken Rockwell disagrees on the sensitivity - his measurements give 103dB @1V, 1kHz
Sennheiser HD 650 review
They are 300ohm cans, need more volts than the average. 2VRMS goes loud enough for me (but I have HD6XX which are essentially the same drivers).
I know everything you know about this times 1000 - Amir @ ASR
Old 12th March 2020, 05:35 AM   #4
gadut's Avatar
being sinusitis and tinitus, I can't listen thru my cans on high level. IEM is already blacklisted for me, my eardrum can't stand it. i have many 10uf from oil to solen, i will try 50uf
good starting point, i might start with SIT which has lower gain. have tried connecting it to your amplifier? btw what is your headamp now? i have amb a20 but unfortunately its psu is not working
Old 12th March 2020, 05:43 AM   #5
abraxalito's Avatar
My amp is my own design MOSFET classA SE. There's a schematic and PCB for it if you like but its only a buffer (gain 0dB). Works fine with a 2VRMS feed from a DAC.
Old 12th March 2020, 06:26 AM   #6
BesPav is offline BesPav  Russian Federation
They can't be burned by most opamps since the relatively high resistance and relatively big diameter.
Say, with 12 V DC in case of amp malfunction will result in only 0,5 W heating.
Tubed designs could be potentially more disasterable due to high voltage, but they mostly have trafo at the output while OTL really needs some DC protection.
Burn them with a signal is a nonsense. Your brains first will be pressed out through nostrills.
Any preferable relay-based DC protection.
Old 12th March 2020, 08:58 AM   #7
gadut's Avatar
@Bespav
thanks for reminding me about ohm law, with my FW clone 25W 14Vrms, yess it should only create small heat. i might consider that dc relay protector
Old 12th March 2020, 02:58 PM   #8
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
You can get a SSR DC protect circuit that will protect your headphones from high DC. However, speaker amplifiers are capable of high transients which can blow a coil and neither DC protection nor capacitors for DC block will solve that. You almost want to use something like 6.8v (or whatever you feel is needed) Zener diodes in series back to back to shunt anything exceeding the Zener setpoint.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th March 2020, 03:48 PM   #9
00940 is offline 00940  Belgium
00940's Avatar
To properly connect headphones to speaker amps, you at first need a resistor divider. This will protect your headphones from excess power and improve the signal to noise ratio significantly. See attached.
On top of it, you can follow the adapter by a dc protection module made for headphones.
All that is excessive is insignificant. Talleyrand
Old 12th March 2020, 06:34 PM   #10
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Project 100
I made Version 2 (2-ohm) of this power amp to headphone adapter, which works fine as long as your amp has low DC offset. DC blocking caps could be added if needed....
Sennheiser HD650 driven by class a amplifer?Hide this!Advertise here!
Sennheiser HD650 vs AKG Q701 QJ otherside Headphone Systems 62 17th January 2013 04:00 AM
Sennheiser HD650 stock cable brendanr Headphone Systems 8 25th March 2012 05:26 PM
Sennheiser Cable for the HD650 JohnerH Parts 4 8th January 2012 04:04 PM
FS Sennheiser HD650 markmelheim Swap Meet 8 24th March 2008 09:15 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
