Headphone Systems Everything to do with Headphones
Noir, a two transistor headphone amp: class-A, single ended, 150mA bias
Old 16th November 2019, 04:22 PM   #31
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Good afternoon,
After a few hours of work I could finish my Noir build today. As Mouser does not ship the recommended wallwart to Europe, I ordered a Meanwell with equivalent specs.
Bias es easy to set to 150 mA and so I went on listening after bias had stabilised.
First tunes over my AKG 712pro were not to talk about, yet it became more soud after a while. So I am curious about how it will sound after some forming hours.
I noticed that the psu cap in the amp is just 330 uF. Somehow I feel inner motivation to put a bigger one on its place. Would this benefit the sound in any way?
Cheers
Ernst
Old 16th November 2019, 06:53 PM   #32
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Ernst, many SMPS wall warts contain short circuit protection circuitry, which falsely triggers if there is "too much" capacitance connected across the supply output pins. For example, the "ACP+" project from Burning Amp 2019, connects about 4000 uF from supply to ground, and this is enough to make the wall wart sputter and belch. They're using 24VDC @ 0.5A. If you experiment with larger and larger amounts of bypass capacitance, it would be wise to unplug the headphones before turning the unit on or off!
On the other hand, why not try it? The worst that can happen is: you'll find out how much capacitance is too much. You'll also find out whether you detect any improvement or degradation in the sound.
_
Old 16th November 2019, 09:38 PM   #33
Thanks Mark for your detailed answer! And thanks for this well documented, complete and easy to build project.
I will play a little bit with it. Maybe I will add some crc part.
Cheers
Ernst
Old 17th November 2019, 02:34 PM   #34
PjVervoorn is offline PjVervoorn  Thailand
Originally Posted by Mark Johnson View Post
PjVervoorn, I haven't tried the modifications you propose, and I don't think anybody else has either.
Hi Mark,
Thanks for your response.
I will start with the specified values and see if I want to experiment.
The batteries are 7.9Ah (replacement UPS batteries), that would virtually double the playing time with the same drop.
Old 18th November 2019, 07:13 PM   #35
A few pics of my amp. Even they might all look the same ;-)
Old 18th November 2019, 07:21 PM   #36
Congratulations on a beautiful build, Ernst! I like your idea to rotate the 6.35mm headphone jack, it made your wiring extremely clean and tidy. It also looks like you are using a "DACT stepped attenuator" volume control. Kudos for personalizing your unit!
Mark
Old 18th November 2019, 08:16 PM   #37
Mark,
Your kind words make me happy! Yes, this is a DACT type attenuator. I like them as they are more matched channel wise, even I wish they were a bit more logarithmic...
And I use old MKC foils. ZM likes them, so I like them ;-)
Cheers, Ernst
Old 23rd November 2019, 08:03 AM   #38
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
It shouldn't be too long before I experience Noir. I've just had notification that my Galaxy chassis is on its way from Italy and the resistors that were out of stock have shipped from Mouser.
Old 24th November 2019, 08:52 PM   #39
batty is offline batty  Australia
Just have to bias mine, but I don't have an adaptor for the US wall power pack.
I have gone from 85 watts class AB amplification to an ACA.Gone on to the M2X.
Old 25th November 2019, 12:26 AM   #40
Member blackdod gave a Mouser part number for an EU compatible wall wart in the old thread, here is a link. It's post #57 in case I bungled the link.
Noir, a two transistor headphone amp: class-A, single ended, 150mA biasHide this!Advertise here!
Single ended class-A headphone amp using two transistors: T2 Mark Johnson Headphone Systems 409 7th October 2019 03:16 AM
GERMANIUM Single ended Class A Headphone Amp. Mooly Headphone Systems 99 12th January 2019 03:05 PM
Interesting transistor for single ended applications oon_the_kid Pass Labs 3 14th April 2018 02:39 AM
The ultimate single ended class a transistor transformer?! dave_gerecke Solid State 3 8th March 2008 12:00 PM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 10:01 AM
Copyright ©1999-2019 diyAudio
