Headphone Systems Everything to do with Headphones
Fast DC protection for HPamps.
Old 30th September 2019, 03:06 PM   #41
stryx is online now stryx  United Kingdom
An ultimate amp protection circuit ?
Old 30th September 2019, 11:33 PM   #42
Mark Tillotson is offline Mark Tillotson
Originally Posted by Elvee View Post
To summarize, from a purely thermal POV, 500mJ should generally be safe enough.
Mechanical effects would depend very much on the construction and are not easily predictable.
Electrically, the 2J were unable to affect it: it stayed at 30 ohm.
Mechanically even 1J is a massive amount to dump into something delicate, its the energy in dropping 1kg weight 4 inches, or 100g (small apple) a whole meter onto the target!
Of course the efficiency of the driver may be low and mitigate this (in other words the vast majority of energy may end up thermal, not mechanical).
The full Thiele-Small parameter set may be useful for estimating voicecoil velocities for a pulse input, perhaps?
Old 2nd October 2019, 02:08 AM   #43
RickTH is offline RickTH
Originally Posted by stryx View Post
I'm surprised that I didn't find that thread when searching the forum for protection circuits. It's a good (long) read. ( I wonder why they banned Esperado ).
The ultimate protection IS comparing input and output . But I'm not that keen on some things in Esperado's circuit , and to implement it to a smaller HPamp .
The mosfets instead of a slower relay is a good way to get over the 5ms relay time , but I'm not that keen on using it . Even the fast output enable of an OPA1622 needs a relay to be 100 % sure .
I'm still going to pursue the InAmp idea , but it's going to be on the back burner . Since the output of any of the DC protectors is the same , I can build it as an extra little module that I can switch if it's not working well .
Fast DC protection for HPamps.Hide this!Advertise here!
Skar Audio T1400.1 protection light flashes fast on/off? 8LayerJunky Car Audio 45 9th May 2016 09:56 AM
Protection Relay Closes Too Fast on Sansui G-7000 Receiver Zekeman Solid State 0 16th December 2013 03:17 PM
How fast does offset protection have to be Mooly Solid State 12 11th May 2008 11:49 AM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Copyright ©1999-2019 diyAudio
