Headphone Systems Everything to do with Headphones
Help troubleshooting Cavalli Liquid Carbon
Old 9th August 2019, 10:59 AM   #11
Nightpuma is offline Nightpuma  Norway
Originally Posted by Nightpuma View Post
I dont have a bench supply unfortunately.
When I unsolder the wires, the amp won't turn on.
Can I solder +16 wire to -16 and vice versa to see if the low voltage changes side?
OK, I mixed up the buttons a little bit. I can tun it on, and the reading is:
+ 16 wire = +15.8 VDC
- 16 wire = - 18VDC VDC
Old 9th August 2019, 12:57 PM   #12
kevin gilmore is offline kevin gilmore  United States
NO. does not work that way. In fact that would do a lot of damage.
You could jumper across the regulators, i.e. -16 tied to -15 and +16 tied to +15
that would tell you if the LDO's are in trouble or not.
Old 9th August 2019, 02:29 PM   #13
When I bypass the reg board, the amps works amp plays on both channels.
Voltage on - and + is almost equal around 16VDC.
So I suppose the conclusion is that the reg is faulty.
I think itīs to complicated for me to fix, so either I:
1. Get a new board from Avenson Audio
2. Get another board that fits.
3. Run the amp w/o reg board.
Will it be ok to run the amp on 16V for now, or should I drop it to 15V with a resistor?
Old 9th August 2019, 05:31 PM   #14
what are the numbers on the 2 LDO chips?
option 1 is highly unlikely or way over priced.
option 3 is the easiest.
absolutely make sure you do not plug in or unplug headphones with the amp on even with the volume at zero.
never ever plug in both unbalanced and balanced headphones at the same time
option 4
make your own perf board with a pair of ldo regulators on it. You should be able to make something by hand using to220 parts that would fit in the case.
Old 9th August 2019, 06:58 PM   #15
option 4
I have taken some pics of the chips. Maybe you can find them. I donít know what to search for.
I will wait for the response from Avenson.
If they donít have it, making one or finding a ready made would be the options.
I like the idea of making one myself. That makes for a nice little challenge for me
File Type: jpeg 25E91860-4F88-42D6-B256-B4FC78F8D668.jpeg (424.6 KB, 70 views)
File Type: jpeg B2EA4348-6674-45BC-9B22-D934DA8FB690.jpeg (375.8 KB, 71 views)
Old 9th August 2019, 08:02 PM   #16
one is this
http://www.ti.com/lit/ds/symlink/tps7a33.pdf
the other is this
http://www.ti.com/lit/ds/symlink/tps7a47.pdf
Old 9th August 2019, 09:43 PM   #17
Thanx
Old 9th August 2019, 09:44 PM   #18
+15V/-15V 1A AC / DC Regulator Power Dual Supply input 15-18V UN-Assembled Kit | eBay
I could maybe use half of this
Or a couple of these:
Voltage Regulator
Old 9th August 2019, 10:30 PM   #19
not the first one. as it clearly will not fit in the box, plus no current limit.
a pair of plus and minus regulators from the second link would definitely work.
Old 10th August 2019, 09:57 AM   #20
Than I will wait for response from Avenson, and if they don't have the original in stock, I will get a pair of the LDOVR regs.
And thank you so much for using your time to help me out. I am very grateful
Help troubleshooting Cavalli Liquid CarbonHide this!Advertise here!
FS:Cavalli-Kan Kumisa III + shuntregulator Ryssen Swap Meet 3 21st October 2016 07:50 PM
Cavalli OCL Buffer Dxvideo Tubes / Valves 30 6th June 2012 11:04 AM
Cavalli-Kan-Kumisa III headphone amp kit h_a Headphone Systems 3 26th May 2010 09:04 PM
riken resistors: carbon comp or carbon film? jarthel Parts 0 20th October 2006 02:00 AM
Copyright ©1999-2019 diyAudio
