Headphone Systems Everything to do with Headphones
Single ended class-A headphone amp using two transistors: T2
Single ended class-A headphone amp using two transistors: T2 Please consider donating to help us continue to serve you.
Closed Thread
Old 18th June 2019, 04:03 PM   #121
twocents is offline twocents  South Africa
twocents's Avatar
Yes thanks, I realized I missed the GB - but am in no hurry (already have too many headamps), but I cannot stop this urge to build.
Would be great if the diyAudio Store can sell them - they can do with more headamp options. In fact, I think many great builds gets missed, lost or forgotten in the GB thread - many more should/could be sold by the Store.
Old 20th June 2019, 02:28 PM   #122
adydula is offline adydula  United States
I sent an email to the DIYSTORE, asking them to stock and sell these boards. They responded very positively!
So send them a note also!
Alex
Old 20th June 2019, 02:57 PM   #123
6L6 is offline 6L6  United States
6L6's Avatar
Good idea.
Old 20th June 2019, 04:15 PM   #124
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Originally Posted by Mark Johnson View Post
Elsewhere on this site I've seen a headphone amp powered by a much more convoluted arrangement: AC mains --> wall wart giving X volts DC output --> DC to DC converter giving X+10 volts DC output --> capacitance multiplier / linear voltage regulator X volts DC output --> headphone amp. Really? Yes, really.
One of mine goes AC->Wall wart->CLC->DC:2DC converter->CLC->LDO->CCS->CRCRC->Amp.......
It is dead silent though....
By the way, parts ordered for the T2 build..
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg, T2. : VSQC Phunk Style, Retro 50W, Filmosound 601, LM4780. : Apex AX-14, TGM-10, TDA7265 (Last in line)...maybe
Old 20th June 2019, 05:09 PM   #125
randytsuch is online now randytsuch
So I thought I had kind of matched the 68 ohm resistors, but this morning I took a closer look at the schematic and realized that they are in pairs, I thought 4 were in parallel because I didn't pay enough attention :/
The anal part of me wants to fix it so they are better matched, really should have bought extra resistors to get a better match, but I didn't.
Guess if I worry about matching, the pair to pair matching for one channel is more important than channel to channel matching?
Other thing I could do is add a larger value resistor to the pairs with higher resistance, to lower them enough to get closer matches.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 20th June 2019, 06:52 PM   #126
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
If you open the "Tweaks, Optimizations, and Silly Changes" pdf file in Acrobat Reader, and if you search for the word stem "match" you will discover that it is never used, not even once. No "match", no "matching", no "matched", nothing.
Matching is not discussed at all. Don't take my word for it, have a look yourself.
You won't find "matched" but you will find, at the end of the first paragraph, some good advice.
Old 20th June 2019, 10:26 PM   #127
If I offended you, I'm sorry, it wasn't the intent.
Thanks again for the boards.
Randy
My system is here
Old 21st June 2019, 03:35 AM   #128
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Was this the amp?
I seem to recall it has a smooth like a baby's bottom noise floor:
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st June 2019, 03:49 AM   #129
avtech23's Avatar
Quite possibly
Old 21st June 2019, 01:38 PM   #130
That amp looks way more complex than the T2 is IMO...many boards and parts. Having a less complex design that works so great is a super plus. Especially for newbies etc...and folks like me that have been building and using more complex designs for years. For me is once again proves simple can be excellent.
Alex
Closed Thread
Single ended class-A headphone amp using two transistors: T2Hide this!Advertise here!
Simple Single-Ended Headphone Amp wrenchone Headphone Systems 45 13th November 2019 10:22 PM
47 Single Ended Pentode Amp/Headphone Amp Gungnir Tubes / Valves 7 10th November 2019 08:13 AM
GERMANIUM Single ended Class A Headphone Amp. Mooly Headphone Systems 99 12th January 2019 03:05 PM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 10:01 AM
Copyright ©1999-2019 diyAudio
