Headphone Systems Everything to do with Headphones
The XEN XELF Headphone Buffer
Thread Tools
Old 17th June 2021, 09:17 PM   #41
lasercut is offline lasercut  Ireland
I can measure, will do for BJTs, but would prefer to mess with the MOSFETs as little as possible... too expensive to risk damage from ESD or another mistake.
I was thinking of trimpot aswell, with 1 power input for both channels traces would need to be cut if you were simply measuring current draw from the supply, is there a better way than that to measure bias current individually?
Old 17th June 2021, 09:29 PM   #42
EUVL is offline EUVL  Europe
Across R11.
Or solder one channel first and measure current draw of lab supply.
Patrick
xen-audio.com
Old 17th June 2021, 09:39 PM   #43
Ok, perfect.
Thanks for helping, hopefully all goes smoothly.
Old 18th June 2021, 03:58 PM   #44
BucketInABucket is offline BucketInABucket  Hong Kong
I downloaded the spice and tried replacing the opamp with an OPA1652, is it normal for the THD to rise a ton? Bias is at 200mA (R9 at 1.7k).
Old 18th June 2021, 05:06 PM   #45
No idea what is in the opamp model.
The XELF input has high impedance.
So it will not load the opamp in any way.
Patrick
xen-audio.com
Old 18th June 2021, 05:39 PM   #46
It's just the OPA1652 PSpice model I found on the TI website. I also replaced the Toshiba small signal BJTs with BC847B/857B but that had no effect really (which is good). Wonder what's going on...
Old 1st July 2021, 04:42 PM   #47
XELF build went smoothly .
It sounds as great as you might expect, very smooth yet very musical and hugely resolving (captures 'weight' of the sound very accurately), not much more you could ask for.
Old 1st July 2021, 04:59 PM   #48
So satisfied customer ?
Photos ?
Patrick
xen-audio.com
Old 1st July 2021, 06:10 PM   #49
It is a bit rough looking, the caps (Nichicon ES non-polar) were backordered so the gold ones are some spares sitting in for now.
Old 1st July 2021, 06:37 PM   #50
What bias, and what load ?
Patrick
xen-audio.com
The XEN XELF Headphone BufferHide this!Advertise here!
Thread Tools
FS: AMB JISBOS Unity Gain Buffer Stereo DIY Kit (Output Buffer for Headphone Amps) MoodySteve Swap Meet 3 7th August 2016 08:57 PM
Headphone Power Buffer Einric Headphone Systems 27 28th December 2015 03:17 PM
Buffer headphone amp percy Headphone Systems 39 11th November 2010 11:14 AM
OP+Buffer pre-amp/headphone monkey29 Chip Amps 0 25th October 2010 10:34 AM
Buffer/Headphone Amp Dan Banquer Headphone Systems 0 29th August 2003 11:14 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
