Attenuate guitar signal on 3V
I have a few old walkmans that I'd like to use with guitar as headphone amps which are practical to use because of 3V supply but guitar signal level is to high and IC's input impedance is low and unsuited for guitar so I want to put some buffer circuit made of bipolar or fet transistors in between. It has to be on 3V also. Does any one has suggestion of such circuit?
PRR
Joined 2003
PRR
Joined 2003
> Does the walkman circuit have
It turns out there were MANY WalkMan circuits, from the original basic to some much more complicated designs. I never knew that the later ones (MEGAbass) had the headphone shell at +1.3V from power common, and a third power amp to drive it. This one's schematic is mind-blowingly complex-- so much that -I- would forget about it and just whomp-up one of the now-common 3V headphone chips with a buffer in front.
