Headphone Systems Everything to do with Headphones
Simple op amp + BUF634 HPA
Old 2nd December 2018, 09:35 PM   #11
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Lots of good recommendations Abrax. But why so down on the OP’s titled opamp buffer? I suppose the LME49600 could be used - about same price and have 500mA and less distortion. But many of those designs floating around.
I recently used an OPA1688 for voltage gain and used a pair of OPA1688 in parallel for the buffer. It’s working out really well. With 18v rails and supply decoupling via 10uF and 100nF x7r’s right on pins basically it is very quiet and sounds great.
Top view (using low ESR OSCON rail caps):
One can take it an extreme of 8 in parallel:
It worked so well I had to box it up and it’s in constant use now. Great as a Preamp too.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 4th December 2018, 05:30 AM   #12
BesPav is offline BesPav  Russian Federation
Originally Posted by mercedese63 View Post
result in high DC offset
Ok, being scared by dozens ov uV typical offset we could use AD8067 with typical less than a pA input bias current.
Input bias current is quite high for a lot of the better bipolar op-amps.
You know first hand we talk about very different parameters. Of course i will exchange that DC offset for high feedback depth through audioband. One could prefer to keep null grounded.
Old 5th December 2018, 05:09 AM   #13
Dibya is offline Dibya
OPA1688 is my most favourite op amp for driving headphones.
Old 5th December 2018, 04:37 PM   #14
DontHertzMe is offline DontHertzMe  South Africa
No Morse
DontHertzMe's Avatar
I know there are plenty of op amp based variants amps out there. I was attracted to the simplicity of this combination, and wanted to give it a try.
I'm currently putting together a through-hole version of The Wire, will post more when it's ready.
Old 11th January 2019, 03:07 PM   #15
ANCdiy is offline ANCdiy
Yas BesPav, thank you for a really good post!
But there is some stuff here, that I don't understand.
In theory an inverting, buffered OpAmp circuit should be very simple (?) as in the picture below:
In your opinion, what kinds of downfalls would this way of wiring it up have?
Old 12th January 2019, 12:01 AM   #16
sgrossklass is offline sgrossklass  Germany
Your input impedance is only 1 kOhm. Probably fine for any device that can drive headphones by itself (DAP, soundcard etc.), but still lower than what's considered normal in the hi-fi world (which would be 10k and up).
Noise gain of an inverting circuit also is 1 higher than signal gain, which becomes rather noticeable by the time you want lowish gains and highish input impedance.
Old 12th January 2019, 03:23 PM   #17
Nothing for!
Letís analyze.
1. Comparatively low input impedance will result in lower noise due to straight impedance lowering and higher distortion due to higher loadind of previous stage. Iíll prefer 2k, too low for noise and too high for previous module.
2. Gain of -10 is too high for headphone use, in my opinion, especially with typical opamp-level supply not more than 15-18 V. High-impedance and low sensitivity headphones could demand higher signal levels with that or even higher gain, but they also demands higher signal voltage which couldnít be achieved with opamp-level supply. Maybe fully-differential opamp like THS4131 could be used in this case, doing this will double output voltage.
3. Noninverting input straight on ground will lower CMRR, but in case of high input bias current could lower output offset.
4. Feedback circuit shown could be used with opamp stable at gain of >~10. But if you doesnít need so high gain and prefer to lower distortion up to 20-30 dB there could be used low gain of -1 with uncompensated high-GBW opamp. So all of excessive gain of uncompensated opamp will be straightly exchanged to higher feedback depth and lower distortion figures, but demand some stabilization circuitry like shown.
Old 15th January 2019, 05:50 AM   #18
Thanks for the feedback gentlemen!
This has gone into my current build thread on this forum
Simple op amp + BUF634 HPAHide this!Advertise here!
Simple BUF634 buffer schematic? sharpi31 Solid State 9 4th October 2011 06:23 AM
Wtb: Buf634 matthewcarlrose Swap Meet 0 24th October 2008 01:56 PM
Buf634?? saurus Parts 5 13th July 2006 02:52 PM
Wtb: Buf634 moe29 Swap Meet 0 27th January 2006 05:08 AM
BUF634 Heatsink Devil_H@ck Chip Amps 14 29th July 2004 06:14 PM
Copyright ©1999-2019 diyAudio
