Tube/Mosfet Lineamp Repurposed for Headphone Duty
In this thread I show a husky lineamp stage built around trioded 6P1P-EV tubes with solid state help. I have moved on since to a line amp that's not quite so monstrous. The purple beast is shown in this thread, starting with post #19.
Tube Integrated Amp
My plan is to take this line stage and use a pair of smallish toroidal power transformers to step down the outputs and drive a pair of headphones. I'll be stringing the thing together today, and will attempt to audition it with bench supplies tomorrow - wish me luck.
Here's the transformer - lineamp lashup ready for auditioning.
Got sounds, this unit needs output transformers with hotter turns ratio. I'm currently using 230 to 15V transformers, would like to replace those with 230 to 22V. I may also configure the basic amp for more gain to make it easier to drive. I was using AKG240 Studio headphones to test, which admittedly aren't the most sensitive cans in the world...
This one was a low-hanging fruit, as the board was already built up. I next want to try a pair of toroids I have at home that have dual primaries and dual 12V secondaries. I'll configure the transformers for 230V primary and series the secondaries for 24V output. This will give me a ~4500 ohm primary impedance for a 50 ohm output load. I also may want to try some of the cheap parafeed transformers from Edcor, which may be better suited for audio.
I also want to try some of the dual dissimilar triodes designed for vertical deflection service - cheap and mostly overlooked .
