Headphone Systems Everything to do with Headphones
What DIY Amps are available for Stax?
Old 5th September 2019, 08:40 PM   #11
agent.5 is offline agent.5  United States
I found these:
the STAX Amplifier
the STAX Amplifier
It seems to be just regular SE amps, with appropriate output transformer.
Old 6th September 2019, 07:06 PM   #12
hpeter is offline hpeter  Slovakia
hpeter's Avatar
it was inspiration for me, but really its just 2 basic stages. it cant go simpler than that.
however over time i did some improvements..see my blog.
so easy, with gains close to phono pre.
..BLOG.. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000 // 4-125a test
Old 6th September 2019, 08:39 PM   #13
JimmyC23 is offline JimmyC23  United States
I don't own a Stax but if I did, it would be the 009s with a Stax DIY SRM-T2.
The ultimate DIY? A Stax SRM-T2! - Do It Yourself - www.Head-Case.org
Old 7th September 2019, 01:31 AM   #14
Is there a schematic? That thread on head case links to many files that are no longer available. I googled and saw some pictures of stuffed circuit boards, and it appears to be an otl push-pull design, with op amps, guessing to be constant current source feeding the tubes. Bi-polar regulated power supply, it seems.
I am not brave enough to buy a 009 without extensive Stax experience. But I think I can start with a L300 or L500.
Old 7th September 2019, 01:39 AM   #15
I read your update. I guess for new builds, you have changed your suggestion to using LL1677 (for JJ 2A3-40) instead of LL1660? I may just do that as I have a quad of JJ 300B sitting idle, and those JJ 2A3-40s basically are just JJ 300B tubes with 2.5V filaments.
Old 8th September 2019, 02:01 PM   #16
hpeter's Avatar
i still use the ll1660/18ma
i do not have 1677, probably never will since i switch sovteks and jj. at moment. been also thinking about eml 2a3 meshes....one day...
as i can tell, one of biggest improvements were the gyrators for drivers. latest update really pops the microdetails. (jfet+ledpv bias fet)
ecc83+ra was too much muffled. it seems the 2a3 capacitance was interfering too much.
i found out that stax you can add some bass. i wrote a more at headfi.
good or bad seal makes bass weak, but if you find the spot in between.....microfoam selfadhesive roll for sealing windows
Old 11th September 2019, 02:28 AM   #17
thuanth43 is offline thuanth43  Viet Nam
For real
File Type: jpeg F19E2088-4C2A-454C-9A44-4B09D4D6072F.jpeg (905.5 KB, 34 views)
File Type: jpeg 752EE836-2F00-4995-819B-9579151D2BAD.jpeg (942.5 KB, 36 views)
What DIY Amps are available for Stax?Hide this!Advertise here!
STAX Anyone? doctorron Headphone Systems 11 26th August 2016 07:27 PM
Stax SRD-7SB energizer adaptor for normal bias Stax headphone. $90. gaetan8888 Swap Meet 1 11th June 2016 02:43 PM
Stax pro SRD-7 hum sfltrack Headphone Systems 2 4th November 2015 12:45 AM
STAX ESS-4A Help! 5544 Planars & Exotics 5 12th September 2011 03:33 AM
Stax SRA-12S ObliVion Solid State 0 12th July 2004 01:29 PM
Copyright ©1999-2019 diyAudio
