Headphone Systems Everything to do with Headphones
Cheap as Chips OPA1688 Low-THD Muscle Amp
Old 2nd September 2019, 07:02 AM   #231
Buzzy is offline Buzzy  Singapore
What does the 2.2k resistor, R4 in schematic in post #1 do ? Is it some kind biasing for the opamp ?
Old 2nd September 2019, 07:11 AM   #232
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I'm not sure, it could be an attempt to keep the impedances at the opamp inputs more or less the same. But then it shouldn't be 2k2 rather the parallel combination of 2k2 and 6k8 which is ~1k6.
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 3rd September 2019, 12:58 PM   #233
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Abraxalito is correct. Make it 1k6 if you want best impedance matching. 2k2 value lets you increase gain by using larger feedback resistor.
Not shown in schematic (but as built) is a 220pF cap from the input to GND for RFI filter for combo 2k2 and 220pF for about 300kHz low pass.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 14th September 2019, 06:10 AM   #234
Got Foam?
xrk971's Avatar
Testing out the 8x OPA1622 amp with an eBay dual TPS7A low noise regulator board set for +/-18.5v and an eBay +/-24v DC-DC step up. All powered from 12v Pb-acid gel cell. Source is 2ppm 1kHz Akitika oscillator, and sound card is Focusrite 2i4. Signal out of amp is adjusted to be 1.0Vpp into 51ohm dummy load. Setup is not the cleanest, so picking up some very low level -120dB 60Hz. But overall, the amp with this PSU shows a -130dB noise floor and 5.7ppm THD with dominatn H2 and about -12dB less H3 and nothing else.
Cheap as Chips OPA1688 Low-THD Muscle Amp-muscle-amp-tps7a-ldo-24v-dc-dc-1-0vpp-51ohms-44k-jpg
Cheap as Chips OPA1688 Low-THD Muscle Amp-muscle-amp-tps7a-ldo-24v-dc-dc-1-0vpp-51ohms-44k-test-setup-jpg
Old 20th October 2019, 09:28 AM   #235
jfetter is offline jfetter  Costa Rica
jfetter's Avatar
Very awesome...!
Old 20th October 2019, 10:01 AM   #236
jfetter's Avatar
Originally Posted by tomchr View Post
In a composite amplifier, you need to simulate all loops. Both any inner loops and the outer/global loop. All loops need to be stable. Finding a good point to break the loop for the stability analysis can be tricky, especially if you have multiple loops.
Tom
Tom, you are of course correct on the loop simulation but I don't have enough mortal time remaining to invest on tweaking the cad models.
So I use the 'trial and error' method combined with hunches, guesses and some nice test equipment.
Bruce
Old 21st October 2019, 06:00 PM   #237
Got Foam?
xrk971's Avatar
I’m working with Jhofland on a new Muscle Amp Lite with only 4x OPA1622 for outputs but a much improved front end topology using OPA1656’s. Will have provision for balanced input sources and even BT option. Power will be via a custom DC-DC converter with linear regulators. Looking forward to comparing it with the correct 8x rig.
Cheap as Chips OPA1688 Low-THD Muscle AmpHide this!Advertise here!
New Audio Op Amp - OPA1688 johnc124 Vendor's Bazaar 56 2nd November 2017 10:38 PM
P-P with some muscle bigjppop Tubes / Valves 43 18th October 2009 09:22 PM
Cheap DAC chips harryeng Swap Meet 1 16th September 2007 09:13 PM
cheap lm3886TF chips? jeffshort2000 Chip Amps 3 8th January 2007 09:38 PM
Help Cheap as chips speaker project DAVOhorn Full Range 2 5th November 2005 04:35 PM
Copyright ©1999-2019 diyAudio
