Nicely done.
One comment though : that 38r output resistor is much higher than you need. A 4.7r resistor would be more than sufficient. Go to the "tech section" of this review to see why.
I will try that, thanks.A 4.7r resistor would be more than sufficient.
Nice work looks like a fun project! If you ever want more power, try a parallel OP1688 and use two 9v in true dual rail supply. Cap couple output and then you don’t worry about DC outburst in case a battery clip fails.
More here including home etch artwork for PCB.
Cheap as Chips OPA1688 Low-THD Muscle Amp
Interesting schematics, so many to choose from and so little time...If you ever want more power, try a parallel OP1688 and use two 9v in true dual rail supply. Cap couple output and then you don’t worry about DC outburst in case a battery clip fails.
Juat realized that above photo was not the dual parallel one, this is:
Another option for a CMOY sized mint tin is the 2-transistor SE Class A "Pocket Class A" or PCA. It sounds terrific - one of the best sounding headphone amps that I have heard.
xrk971 Pocket Class A Headamp GB
Yes, I already was searching for the other opamps haha.realized that above photo was not the dual parallel one
The 'Pocket Class A Headamp GB' intrigues me but the BF862 seems a bit 'exotic'.
Suppose nearly the same quality is possible with common through-hole components and the circuit would keep its 'simplicity'. Wouldn't it get the same status as the Cmoy amplifier being build by hundreds or more?
A possible title for a new thread would be: 'the simplest headphone amplifiers using discrete components' or something like that.
There is indeed a through hole version called the DCA. The BF862 is a very nice low noise JFET originally designed for mass production use in things like FM/AM radios. It’s at EOL, so harder to find. I have new simulations for a replacement 2SK209 that’s easier to find. You can also use the “exotic” unobtainium 2SK170 - or recent LSK170. New resistor setpoints have been calculated for all 3 JFETs.
DCA is here:
xrk971 Desktop Class A (DCA) Headphone Amp
Has built in cap Mx PSU with CRCRC.
There are probably over 200 of the PCA amps out in the wild.
DCA is here:
- Headphone Systems
- Cmoy pcb too big
