Headphone Systems Everything to do with Headphones
Headphone Buffer Amplifier
Old 4th August 2018, 06:31 AM   #21
EUVL is offline EUVL  Europe
> But the THD distortion is not nice - THD 0.287% is not acceptable.
I got 0.03% THD at 0.92V pk on 32R with 120mA bias.
Patrick
xen-audio.com
Old 5th August 2018, 05:02 AM   #22
PRR is offline PRR  United States
PRR's Avatar
At that higher idle current, I get 0.04% with matchbook math.
It's mostly about the gain (NFB) and the current swing (as fraction of idle current).
Old 5th August 2018, 05:13 AM   #23
120mA is not high for 32 ohm.
Patrick
xen-audio.com
Old 7th August 2018, 01:25 AM   #24
edmortney is offline edmortney
Low-impedance (under 50 ohm) headphones will play well at home with your receiver and on-the-go with your smart phone, and that's why the vast majority of in-, on-, and over-the-ear headphones are low-impedance designs. High-impedance models are much better suited to home than on-the-go use. Sennheiser and Beyerdynamic are two companies that offer high-impedance consumer headphones with up to 600 ohm-rated designs.
Audioreputation.com
Old 7th August 2018, 04:08 AM   #25
miro1360 is offline miro1360  Europe
I did this one, but I did not have time to test it in reality ...
https://ctrlv.cz/shots/2018/08/07/ETvB.png
https://ctrlv.cz/shots/2018/08/07/FGck.png
PCB 5x5cm:
https://ctrlv.cz/shots/2018/08/07/lTxw.png
https://ctrlv.cz/shots/2018/08/07/cPej.png
https://ctrlv.cz/shots/2018/08/07/MZqW.png
THD=0.002%/20k (250mW/32R)
IMD:
https://ctrlv.cz/shots/2018/08/07/Ase2.png
0.06%/19k+20k (50mW/32R)
OLG:
https://ctrlv.cz/shots/2018/08/07/4iVr.png
Old 7th August 2018, 04:36 AM   #26
It's a Scott Wurcer Phono without RIAA but with NFB.
A simplified universal differential or single ended phono preamp
Patrick
xen-audio.com
Headphone Buffer AmplifierHide this!Advertise here!
FS: AMB JISBOS Unity Gain Buffer Stereo DIY Kit (Output Buffer for Headphone Amps) MoodySteve Swap Meet 3 7th August 2016 07:57 PM
No-gain diamond buffer headphone amplifier advice BuckarooBanzai Headphone Systems 14 26th April 2016 05:04 AM
SIT Headphone amplifier (VFET S.F. buffer) gantez Headphone Systems 5 2nd May 2015 12:30 PM
OP+Buffer pre-amp/headphone monkey29 Chip Amps 0 25th October 2010 09:34 AM
Headphone amplifier with buffer anbello Headphone Systems 11 1st August 2008 09:59 AM
