Headphone Systems Everything to do with Headphones
How to power two channels with batteries?
Old 10th April 2018, 03:29 AM   #1
periclimenes is offline periclimenes
Default How to power two channels with batteries?
Hello,
I'm trying to build the circuit shown here
to be powered with a 9-volt battery. I want to build this in stereo, so I'm wondering what is the best way to power two channels. Do I have two independent channels? Two batteries wired together to make 18V and the channels jumpered together? 1 9-volt to jumpered channels? +9V into one channel and -9V into the other?
Thank you in advance.
Old 10th April 2018, 08:54 AM   #2
vsmusic is offline vsmusic  Russian Federation
In this scheme, for each channel it is necessary to use a separate battery . 2 channel - 2 battery . Just make 2 identical circuits , as shown in the photo
This scheme was used in the serial device Marcof - there were 2 channels with two separate batteries . Marcof Electronics Custom Electronics - - Product Brochure - Vinyl Engine
Old 10th April 2018, 03:06 PM   #3
Thank you for your help. Is there a reason why it's not a good idea to run both circuits in parallel off of 1 9-volt battery (other than the battery life)?
Old 10th April 2018, 03:23 PM   #4
sgrossklass is offline sgrossklass  Germany
The output signal is imposed as a common-mode signal on the battery terminals with respect to circuit ground. IOW, the battery terminals carry your output signal. Hence they must remain floating.
Old 10th April 2018, 03:28 PM   #5
benb is offline benb  United States
Yes, the battery is 'floating' relative to ground and has the signal connected to it. If you try to power two of these circuits from the same battery, the signals will be connected and each output will be mono, having both input signals.
Old 11th April 2018, 12:47 AM   #6
That makes sense. Thank you for explaining that on a basic level for me!
Old 11th April 2018, 07:27 AM   #7
Default Question about ground vs. chassis ground
Hello. I'm trying to make a board for this circuit. The board will be placed into a metal enclosure and use RCA connectors. Since the RCA input ground terminal will be in contact with the metal chassis of the enclosure, I think I'll need to connect the RCA in/chassis ground/circuit ground like this:
Is that correct?
For the output, is there any point in connecting an additional wire from the RCA ground terminal to the circuit ground on the board, as shown? If so, will it mess things up that there's another chassis ground point on the other side of the circuit? Do I need to insulate the RCA out ground from the chassis?
As I design the board, are there components that should not be close to one another? My first guess is that, since it's all DC, the placement of the circuit elements isn't as critical, and I can pack them all pretty close to one another.
I'd appreciate hearing your perspective on how I should populate the board.
Thanks in advance
Old 11th April 2018, 08:55 AM   #8
On your circuit there are errors . C1 is not connected properly - make as in the original scheme . For the transistor 4401 is equivalent to the pair is the transistor 4403 . Apply the layout of elements in the product Marcof ( download the brochure on my link ) - it's got pictures inside . It was a serial product .
Old 11th April 2018, 03:59 PM   #9
Thank you for helping me. I changed the schematic so C1 is as in the original scheme. Does this look better?
If this is correct, I don't understand the difference between circuit ground and chassis ground. Is it okay that they are the same? Or do I need to insulate the ground tabs on the connectors from the chassis?
Also, I'm not sure what you mean when you said
Can you please explain?
Old 11th April 2018, 04:26 PM   #10
The transistor 4403 is a complementary pair of transistor 4401 . They have the same electrical parameters . Using another transistor may impair the symmetry of the modes of operation of the circuit . This may affect the sound quality .In the original Marshall Leach scheme is applied to the transistor 4401 and 4403 .......The scheme - now everything is correct . Also it would be correct to connect the ground of the input connector to the metal chassis of your device without capacitor C1 .It will work ....
How to power two channels with batteries?Hide this!Advertise here!
Draw power from one of two batteries in series seemtorecall Power Supplies 6 3rd April 2013 12:23 PM
Two Objective 2's Work on Batteries, not AC Power jschristian44 Headphone Systems 3 23rd January 2012 08:26 AM
FS: O2 Amp Complete with batteries and power supply networld Swap Meet 1 11th December 2011 03:55 PM
Batteries for power amps? ggking7 Power Supplies 11 20th September 2010 06:04 PM
Batteries as power-supply filters? Dartagnan Solid State 3 6th October 2004 06:08 PM
Copyright ©1999-2019 diyAudio
