Headphone Systems Everything to do with Headphones
Very Simple 3BJT Headphone Amplifier
Old 3rd October 2019, 06:25 PM   #41
syrbinche is offline syrbinche  Germany
Great circuit! I have just tested it and it's really good! Very very loud, so i have to lower that otherwise gonna burn my headphones
I took 10ohm resistor in the R4 position and have like 90mA thru 2xBD139
I have +/-24V power in my setup and i wonder if this could be modified for 48V?
Does it make sense to do that?
Old 3rd October 2019, 07:25 PM   #42
Osvaldo de Banfield is online now Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
What warranty that both hemicycles receive equal amplifying factor (or gain)? The input transistor has a gain of about 10 (1200Ω collector/120Ω emitter). The upper final transistor is a follower, so gain ≈1. The lower final transistor ???
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 3rd October 2019, 07:47 PM   #43
Mark Johnson is online now Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Sounds like a question that motivated hobbyists might attack very quickly using circuit simulation software.
Old 3rd October 2019, 08:07 PM   #44
Yeah, but over any simulation, is good to know what one is doing, because if not, you can't understand what the simulation is saying to you.
This is like an example, a professor told us in the university. Suppose you have a tester (VOM) that is malfuctioning. Suppose also that with this VOM you read 50V, for example, in the 220V power line. Do you touch the wires under those conditions?
Old 3rd October 2019, 08:36 PM   #45
diyAudio Donor
Fantastic! Good luck and best wishes.
Old 12th November 2019, 03:40 PM   #46
gasboss775 is offline gasboss775  United Kingdom
gasboss775's Avatar
In LT spice I tried replacing the 1K2 resistor with a current source using a jfet and resistor. The THD was reduced to around 0.09% ( mostly 2nd order )
offense is the collateral damage of free speech - Ricky Gervais
Old 21st November 2019, 05:36 PM   #47
gasboss775's Avatar
I have built the original circuit using both TIP41 and 2SC3852A transistors and would say it definitely sounds better with the TIP41s.
Old 21st November 2019, 10:53 PM   #48
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Have you tried it with the jfet current source to compare with the original design?
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg, T2. : VSQC Phunk Style, Retro 50W, Filmosound 601, LM4780. : Apex AX-14, TGM-10, TDA7265 (Last in line)...maybe
Old 22nd November 2019, 06:52 PM   #49
gasboss775's Avatar
Yes, but not thoroughly tested. First impression was there was greater clarity at the high end.
The open loop gain was much higher as expected.
Note these comments pertain to using TIP41s as the output transistors, with the 2sc3852a's it sounded bad! Very muddy and distorted.
I used a J112 and a 180 ohm as the current source the current was around 10.5mA. I will probably try again with other jfets.
Old 23rd November 2019, 09:44 PM   #50
Mark Tillotson is offline Mark Tillotson
The 2SC3852 is extremely high current gain (guaranteed > 500), so there's a lot of feedback available. The circuit is dominated by feedback, and that transistor enables it to perform very well. The gain is stabilized by the feedback (masking imperfections of the output stage).
Give it a more linear output stage it will perform even better I suspect. The lower transistor is the obvious low-hanging fruit.
Very Simple 3BJT Headphone AmplifierHide this!Advertise here!
Power supply recommendation for simple hybrid headphone amplifier DontHertzMe Power Supplies 1 2nd June 2014 03:03 PM
My first and simple headphone amplifier - class a ChristianH Headphone Systems 4 15th September 2013 09:34 PM
Looking to hire someone to help with simple headphone amplifier design FasterHorses Chip Amps 4 17th May 2011 08:45 PM
Simple Headphone Distribution Amplifier TheSeekerr Headphone Systems 7 28th November 2010 12:08 PM
A simple Headphone amplifier. Kapibara Headphone Systems 3 20th July 2007 09:55 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
