Headphone Systems Everything to do with Headphones
The Pioneer Super Linear Circuit
Old 8th November 2018, 05:55 PM   #241
passive420 is offline passive420  United Kingdom
Thanks Patrick, this had crossed my mind actually and nothing is set in stone yet. Just looking now and certainly there would be less jumping around with the amps near the front and Xfeed.
Old 9th November 2018, 12:57 PM   #242
Very pleased with the build so far, the regulator wiring is perfectly straight forward and neat. The TeddyRegs are excellent to be fair, rock solid 15.08V on each, I did a decent job on those at least.
The rear solder turrets on the motherboard have been connected with solid wire as a bus bar - all signal 0V's will return to this bar. They will be the only wires to cross the regs and will fly down the middle running along the T-bar heatsink.
Patrick, I think I can run all signal around the regs completely, in a tidy manner. Hopefully show you later. Fingers crossed no 50Hz hum. The input 0V's are also solid wire down the middle, the input signal wires will pass down the side and over the pot to the Xfeed. I'll try and use Van Damme shielded cable for the input at least. All 0V's from the SHPP and output jack will go to the bus bar.
Not sure what else to tell you right now but she's looking good
BadBoyGolf asked which chassis I have used, it is this one from ebay, tailor made for this motherboard if you wanted heatsinks. -
Class A Aluminum Case/Preamp box/ Amplifier Enclosure/ Mini Amp Chassis HIFI Box | eBay
Now there is no hole for headphone Jack, just for a small power button. So you will need a 24V drill or one with lots of torque and a step hole drill to suit your phone jack. Neutrik D shell is around 24mm so open up the button hole and for me, I will use a switch on the back panel... I forgot to make a hole for an front panel LED actually.
3PC LARGE HSS STEP CONE DRILL TITANIUM BIT SET HOLE CUTTER + STORAGE POUCH | eBay
Coffee and eggs for me now...
Old 9th November 2018, 02:44 PM   #243
Ok last entry today, I need to build the SHPP.
Just to show Patrick that hopefully the signal wires will avoid crossing the regs. Once things are soldered and cable tied nicely, we should be in business.
The SHPP is powered directly from the motherboard 15V outputs, wires run under the regs.
Connecting the outputs from the under the pot is slightly awkward, pads for pins at the rear of the pot would be better I feel. I may use pluggable Molex type connectors for the SHPP.
Old 9th November 2018, 03:10 PM   #244
EUVL is offline EUVL  Europe
The case is just a standard Breeze Audio 2107, like the one we used.
Douk Audio Universal Chassis Aluminum Box Amplifier Enclosure Verstarker Gehause | eBay
Patrick
xen-audio.com
Old 9th November 2018, 03:18 PM   #245
As I already said, the input wires from the X'feed will be n-times shorter
and much further away from any power supply lines
if you place the ampboards in the middle, especially with the input facing the front.
But it is your build, so as long as you are happy with it, it is the most important.
I only made the comment for others who might wish to consider similar layout.
They may also look at the Super Linear Current Amp thread for another layout using non-SMD X'feed.
The pot was placed as close to the X'Feed as possible, using shaft extension.
Current Drive for Headphones & The Super Linear Transconductance Amplifier
Patrick
xen-audio.com
Old Today, 12:25 AM   #246
For the sake that it might be of some help to someone when they start, here is my SHPP board finally. I neglected to order zero ohm chips for some reason but they are on the way...
So I would advise the GB members when ordering the SHPP BoM to get 0805 size parts in place of 1206 parts specified. The PDF does mention going down one size but you will be ok with 0805 for all components.
The cluster around the op-amp is tight, work your way outwards and solder the central pads first. Tin one pad, apply liquid flux and slide the component in as you apply heat. Then adjust making sure they cover both pads equally.
Double check LED and diode orientation every time, the markings are hard to see both on the board and the parts themselves.
This SHPP board is possibly one of the most challenging SMD assemblies I have done, but I enjoy that. Get a good loupe or magnifying glass and check every solder joint each time. I fought a while with a solder bridge across R13 and C3, only to see that they are connected anyway... Using continuity test is a good way to check things.
As a glimpse into my mind, R5 on the right side first pic is killing me, all skewed and that. I hate it, it's bound to effect sound quality... we'll see. This is one of my messier jobs really looking at the pics but If I don't think about it I'll be ok
Old Today, 12:32 AM   #247
Before downsizing, you should check capacitors has sufficient headroom in voltage rating, and resistors will take the power.
For example R20, and the input filtering caps to the opamp.
Do not forget that X7R capacitors loses > 50% of their capacitance when they see a DC voltage close to their rating.
You will find lots of information on the net.
Patrick
xen-audio.com
Old Today, 12:43 AM   #248
Out of interest Patrick is there any issue (other than cost) with using higher quality 35v Tantalum caps for C1,2, 11,12?
https://www.mouser.co.uk/ProductDeta...e0t90lBQ%3d%3d
Old Today, 12:49 AM   #249
Yes, because tantulum is known to fail by short circuiting.
And you need even more voltage headroom than X7R to prevent that.
I have avoided tantulums altogether for the last 10~15 years.
Patrick
xen-audio.com
Old Today, 12:52 AM   #250
interesting, thanks
The Pioneer Super Linear CircuitHide this!Advertise here!
Sony Super Legato Linear latala Solid State 12 23rd January 2015 05:56 PM
AES E-Library: Super Linear Circuit by Ozawa, Okio; Ishikawa, Kikuo aparatusonitus Solid State 16 17th January 2012 10:49 AM
Linear PSU circuit gabanyayaya Power Supplies 7 21st July 2011 01:00 PM
Phase Linear 200 Circuit mrfeedback Solid State 4 5th December 2004 10:48 AM
