Headphone Systems Everything to do with Headphones
Hybrid tube/MOSFET headphone amp
Old 19th March 2016, 01:15 AM   #1
davygrvy is offline davygrvy  United States
davygrvy's Avatar
Lightbulb Hybrid tube/MOSFET headphone amp
I was messing around in SPICE and think I solved the PSRR problem with a white cathode follower using depletion-mode MOSFETs. I appear to have given it a 26dB improvement.
Is it elegant or another lame-o dud?
The top jfet gets the current sense relative to the supply and send it to the bottom one that inverts and adjusts for matching swings.
Think out of the box
Old 19th March 2016, 07:08 PM   #2
davygrvy's Avatar
Here's a slightly different one that can bring a 25 ohm Denon AH-D2000 to its full 1.8 watts.
I changed the VAS p-device to a Supertex VP0550 which allows the I-to-V resistor to be larger as the D-MOS turn-on is much higher. This gives much more open-loop gain. Each output device dissipates just 900mW at full load or 1.3W at idle.
Old 19th March 2016, 08:28 PM   #3
davygrvy's Avatar
That CCS with the LND is superfluous
File Type: png Screenshot from 2016-03-19 13:28:52.png (42.1 KB, 333 views)
Old 20th March 2016, 07:52 PM   #4
davygrvy's Avatar
PSU will look something like this using a Hammond 12.6VAC or similar TXFMR
File Type: png Screenshot from 2016-03-20 12:47:21.png (32.3 KB, 312 views)
Old 6th April 2016, 07:41 PM   #5
hpeter is offline hpeter  Slovakia
hpeter's Avatar
i like how its done. +1
been thinking similar but with semelabs lateral
..BLOG.. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000µ // 4-125a test
Old 6th April 2016, 07:43 PM   #6
davygrvy's Avatar
Those are enhancement mode. I guess you could do white cathode follower with them, but it won't self-bias
Old 6th April 2016, 07:47 PM   #7
hpeter's Avatar
triodes are like self fb, plate is signal out, but at same time could be used as fb input.
when triode is working into opt, that´s easy.
how to make it work in other schemas..quite hard
Old 6th April 2016, 07:54 PM   #8
davygrvy's Avatar
Interesting.. A small change to get the bottom biased, and this might just work.
Possibly not tempco stable, though.
Old 6th April 2016, 08:02 PM   #9
davygrvy's Avatar
Ooops, Semelabs... sorry.. The spice I did for the Semisouth power SiC JFETs. I was wondering why you asked about.. give me a few moments. a BUZ900, okay?
Old 6th April 2016, 08:14 PM   #10
davygrvy's Avatar
For a BUZ901P. I like it
Hybrid tube/MOSFET headphone ampHide this!Advertise here!
reliable tube/mosfet hybrid amp JAZZ2250 Solid State 90 9th May 2019 04:03 AM
6CG7 Hybrid Tube Headphone Amp Einric Tubes / Valves 27 29th December 2015 01:37 PM
GLASS-SAND CLASS A TUBE MOSFET HYBRID HEADPHONE AMP roline Headphone Systems 24 7th November 2013 10:46 PM
Hybrid tube headphone amp design ashok Headphone Systems 21 30th December 2012 05:17 PM
Portable Tube/Hybrid Headphone Amp petesjoy Headphone Systems 1 15th November 2009 12:57 PM
Copyright ©1999-2019 diyAudio
