Headphone Systems Everything to do with Headphones
QRV04 Headphone Amp. + Red Baron v5 DAC
Old 12th November 2015, 10:56 AM   #1
savinalexandru is offline savinalexandru  Romania
Default QRV04 Headphone Amp. + Red Baron v5 DAC
Hi everyone,
I would gladly listen of your opinions regarding conecting this two pieces of DIY as i try to figure best solution.
1. Active or passive I/V stage before conecting to qrv?
2. Conecting to qrv directly to Tda1542 pin is possible?
3. Input caps on qrv does influence sound greatly, so i could remove the smd type and put some Mundorf for example?
4.removing completly the input caps on the qrv and put sowther transformers between dac and the headphone amp.?
Ps: sennheiser hd600 listening cans.
Thanks in advance for your help!
Alex.
Old 12th November 2015, 12:07 PM   #2
sgrossklass is offline sgrossklass  Germany
That DAC has the usual DAC-related tinkerer-level audiophile snake oil pretty well covered, save for exotic capacitors. I am not denying that passive I/V can be useful, but that's just because you didn't put in enough filtering effort to get rid of all the high-frequency crap coming out of the converter beforehand. That sort of stuff tends to irritate bipolar input opamps in particular, a reasonably fast-slewing FET input parts tends to be beneficial.
You know, most people would probably prefer a DAC that actually works properly. Like, say, a decent onboard audio output. Or an ODAC if you want a higher level of performance and USB is your thing. Or whatever (some sort of decent PCM5102A based job maybe). DACs are mostly a solved problem though I guess some people still prefer shooting themselves in the foot.
The QRV04 is good. It allows you to experiment with some output series resistance (for a somewhat fuller bottom end on HD600s, try values of like 2x 100 ohm to 2x 200 ohm, giving 50-100 ohms). Be sure to populate the input filter components. As for the input coupling caps, I'm sure Per-Anders doesn't specify any crap-quality components, plus you could still generously oversize things even if you were forced to use MLCC ceramics. If your DAC output is AC-coupled, you could even replace them with simple wire links / 0-ohm resistors. I would never use any of these ridiculously huge Mundorf speaker crossover film caps in such a place, just some decent WIMAs or Panasonics.
I see the power supply does not use capacitors from the regulators' ADJ pins to ground. Those may be worth adding, like 10 F (25+V) electrolytic. It shouldn't matter much in terms of noise, but regulation / transient behavior should improve.
Old 12th November 2015, 07:04 PM   #3
10x a lot for great info.
I will try to get that smd Evox Riva caps that P-A is recommending. (although is hard to find them)
Second, you're probably(sure) right, but my pleasure to tinker and plant all components on a pcb is greater than buying a fully built dac.
BTW, you're right i'm going to use USB. WaveIO seems a good choice?
About supply, all powered by shunt regulators. It's going to be a big box....and a LOT of tinkering!
Rgs,
Alex.
QRV04 Headphone Amp. + Red Baron v5 DACHide this!Advertise here!
FS LL1694 , Red Baron V5 tube Izar Myint67 Swap Meet 6 14th May 2015 01:13 AM
Red Baron TDA1541 monster dtses Swap Meet 3 31st January 2015 05:04 PM
DAC/Headphone Amp Peter Menting Swap Meet 3 9th June 2014 02:21 PM
FS..Red Baron Dac V4 beardman Swap Meet 3 31st October 2013 10:22 AM
Red Wine Audio Dac/Amp lpd Swap Meet 3 28th February 2013 09:11 PM
Copyright ©1999-2019 diyAudio
