I recently built a pair of headphones and added an audio jack input to both the cans, for convenience of connecting.
That would also serve another purpose of letting my girlfriend hear the same music without me having to take off the headphone.
But the problem I noticed is that the volume gets reduced. Now this is primarily because its getting connected in parallel, so is there any way to subdue the problem.
Thanks.
Thanks.
Yes, there are usually series resistors (of roughly 100 ohms) on the amplifier outputs
going to the stereo headphone jack. Just reduce the value of both resistors by at least half.
@rayma, how would I do that if I am just using the headphone to listen from my phone.
Then you need an external "booster" amplifier that can drive both. The phone can only do so much.
Yup. Usually headphone amps with two output jacks use individual series resistors for both, in order to circumvent this very problem.
It would also seem that output impedance on this particular phone may be a bit high. Lesser ones may well sport as much as 47 ohms, while the multi-driver BA in-ear crowd tends to be after models with a few ohms at best, or sub-ohm in some cases. Unfortunately one model phone often exists in multiple versions depending on region or features like LTE, and those may well be different.
I wonder how these companies solve the problem?
https://www.urbanears.com/ue_asia_en/humlan/#176=150
BeoPlay H6 - Premium materials delivering top sound quality
- Headphone Systems
- Headphones with dual jack, reduced volume
