Headphone Systems Everything to do with Headphones
class A Buffer
class A Buffer
Old 10th January 2016, 03:33 PM   #91
misterzu is offline misterzu
..yet another class A buffer idea (didn't test in HW yet)
Old 16th January 2016, 09:47 PM   #92
theophile is offline theophile  Australia
theophile's Avatar
I'm just lurking here.
[ Turntable - Yamaha GT 2000 ][ Cartridge - Soundsmith 'The Voice' Ebony ][ Phono Preamp - Simaudio Moon LP 5.3 ][ Preamp - Hornshoppe 'The Truth' ][ Speakers - KRK Expose E8B Monitors ]
Old 30th June 2020, 09:10 PM   #93
laserscrape is online now laserscrape
Originally Posted by Calvin View Post
You may omit with R4. R5 has negligible impact and may be raised to 1k.
C3 should be a bipolar cap.
optional:
- You may split R1 in two resistors with increased value (5K-10k) and add a cap of a few F from the resistor mid-joint to the negative supply.
- You can omit with the output coupling caps using a active DC-servo that controls the idle current of the ccs, and a bias voltage and a source resistor for the MOSFET.
For an example of the servo circuit see my website calvins-audio-page.jimdo.com/ideas-and-circuits/buffers/hybrid-buffer-en/.
Scroll down to "Calvin-Buffer plus dc-servo".
jauu
Calvin
Hi, Calvin
I checked out your site but couldnt find that servo, however I came across your page on BJT buffers and something stuck out.
Regarding emitter followers you mention :
''As can be seen in the pictures, the circuit works with a single supply voltage, but can also be used with a dual symmetrical operating voltage. With good transistor matching and clean adjustment, the output capacitor can then be dispensed with.''
I did not think this was possible for EF circuit without a servo, and this is exactly why I am searching for servo.
Would you mind elaborating more on that circuit, an EF without output coupling cap?
class A BufferHide this!Advertise here!
Another implementation of Class A buffer for headphone B&W_arthur Headphone Systems 20 5th February 2015 11:32 AM
Class A Follower Buffer? Logistics Pass Labs 10 4th September 2014 05:20 AM
Inverting headphone buffer class A kacernator Solid State 6 18th January 2013 05:56 PM
Class A Buffer Op amp ttan98 Chip Amps 8 12th August 2011 06:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
