Headphone Systems Everything to do with Headphones
RJM Audio Sapphire Desktop Headphone Amplifier
Old 22nd August 2019, 04:13 AM   #1511
DRONE7 is offline DRONE7  New Zealand
Boards assembled and working... offset set at 5mv but can go lower.
Testing on the bench with a discman and Lightspeed attenuator .
I did use thermal paste because....why not..
I note that the Q14/15 pair runs noticeably warmer than the Q13/16 pair.....just the finger touch test but the same for both boards...
I am about to take them inside to the main system and will raid the medical cabinet for the digital thermometer and recheck..
Otherwise....sounding great and no hiss clicks pops hum sparks or worries of any sort...!!
Having built the Emerald Phono stage and now the Sapphire I have to say that these are the most diy friendly projects I have ever encountered.
The build guides are comprehensive and the "Design Manual" provides great insight and options...and best of all they power up and work first time.
Thank you Richard for sharing and supporting !!
Old 22nd August 2019, 09:31 AM   #1512
Mixi is offline Mixi  Europe
Glad to see that the "Design Manual" idea gets so much traction.
Thanks for the quick reply, Richard! I think this has to be my next DIY project. I'll now try to understand the circuit. I've built a few opamp based designs, no discrete circuitry so far. ....apart from an ACA and B1 I guess but that is super simple.
Old 23rd August 2019, 01:59 AM   #1513
rjm is online now rjm  Japan
Richard Murdey
rjm's Avatar
That's strange. With 30 mA bias neither pair of transistors, nor the heatsinks, get appreciably warm. The heat dissipation of each pair is less than 1 W total.
Check the voltage drop across R17 and R18. They should be equal and the current, computed as I=V/R, should be the expected value for the bias current setting.
Richard
RJM Audio | phonoclone.com
Old 23rd August 2019, 04:26 AM   #1514
Fingers are such sensitive things....
I remeasured with the thermometer and Q14/15 pair is only 4 degrees C warmer than Q13/15.
Voltage drop across R17 and R18 measures the same for each.
Bias current measures 39 mA and highest heatsink temp is 42 degrees (20 above ambient) so all appears as expected and normal.
Old 23rd August 2019, 12:24 PM   #1515
Richard Murdey
rjm's Avatar
That sounds about right!
Old 20th September 2019, 12:05 AM   #1516
withmatt is offline withmatt  South Korea
Default Mini Sapphire 4
My mini version Sapphire 4 implementation.
(Sorry for Korean)
SCU-SAP4 : 네이버 블로그
Old 20th September 2019, 12:32 PM   #1517
Richard Murdey
rjm's Avatar
Well that is incredibly cool.
I'm most impressed how you managed to condense the transistor stack like that and put two channels on a single board without going to SMT. I realize you moved the regulators off, but still... great job!
Old 23rd September 2019, 04:09 PM   #1518
Default mini Sapphire Gerber.
For those how requested Gerber.
RJM Audio Sapphire Desktop Headphone AmplifierHide this!Advertise here!
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 14 2nd September 2016 11:23 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 09:43 PM
Copyright ©1999-2019 diyAudio
