Headphone Systems Everything to do with Headphones
RJM Audio Sapphire Desktop Headphone Amplifier
Old 29th May 2019, 12:33 PM   #1491
kamoris is offline kamoris
Hi
Maybe a silly question but i want to build ver.4,
i check schema and board in eagle. On schema tehere is nice ground path conencting gnd, zeneres, caps and etc.
But on board there is no connection. Is it right or something wrong is with my eagle ??
On print screens i shows what i worry about.
Old 29th May 2019, 11:08 PM   #1492
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
When you load the .brd file into Eagle the polygon fills are only indicated by a dotted outline. Click the "ratsnest" button to fill the polygons and properly display the Sapphire's ground plane.
RJM Audio | phonoclone.com
Old 31st May 2019, 07:09 AM   #1493
Ok i do it, now it seems ok. But i just already ordered pcb from jlc, hope that gerbers will be fine ( i genereated these file wihtout cliking rastnest button).
Will see when pcb will come next week.
Also i have next question. How crucial are parameters of c10,11 bypass capacitors?? Then can vary slight?? And is it must be x7r capacitors ?
Old 31st May 2019, 12:46 PM   #1494
Richard Murdey
rjm's Avatar
The polygons are present whether they are visible or not, it does not effect the Gerber data.
No particular requirements for the bypass caps, except reasonably low ESR.
Old 25th June 2019, 01:33 PM   #1495
Dibya is offline Dibya
Which resistor are used in this amp ? The black resistors looks classy.
Old 11th July 2019, 11:25 PM   #1496
Richard Murdey
rjm's Avatar
The black ones are probably Welwyn. They were discontinued a long time ago.
Old 11th July 2019, 11:28 PM   #1497
Richard Murdey
rjm's Avatar
One of my recent emails was from someone asking about running the Sapphire from a single 12 V supply.
It's doable, with some performance hits due to the reduced voltage and asymmetrical design. The simplifications might be worth it for some however, so I'm thinking about at least making a board layout for it. It can be a headphone amp or a preamp/line driver.
Anyone else interested?
Old 12th July 2019, 05:41 AM   #1498
EUVL is offline EUVL  Europe
You can just add a Jan Didden Silent Switcher, with which you can generate low noise +/-15V from a single supply as low as 5V (USB).
No need to compromise.
The SilentSwitcher | Linear Audio NL
SilentSwitcher - mains-free +/-15V and 6/5/3.3V power
Patrick
xen-audio.com
Old 12th July 2019, 05:47 AM   #1499
For portable applications, I have also used LTC3265, which is all in one.
New Audio Op Amp - OPA1622
(Post #297)
Patrick
xen-audio.com
Old 28th July 2019, 04:20 PM   #1500
Uncle Fedor is offline Uncle Fedor  Russian Federation
Default some questions about
hello there
i want to build the sapphire v4 amp and i have couple of questions
1. the schematic looks symmetric. can i bypass input capacitor - if there about 0 dc in this point?
2. can it be scaled to drive small speakers? what changes will be needed for this (power source, parallel output stage transistor, etc)
3. where to buy pcbs or kits? maybe i can find all components to build the amp but i have no experience with making pcb.
thanks
RJM Audio Sapphire Desktop Headphone AmplifierHide this!Advertise here!
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 14 2nd September 2016 11:23 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 09:43 PM
Copyright ©1999-2019 diyAudio
