Headphone Systems Everything to do with Headphones
RJM Audio Sapphire Desktop Headphone Amplifier
Old 11th February 2019, 12:31 AM   #1471
itsikhefez is offline itsikhefez  United States
Originally Posted by rjm View Post
14 ohms is quite punishing, even if the efficiency is reasonable. You can see from the attached image that the output power of the Sapphire in the standard 37.5 mA bias configuration drops off considerably below 60 ohms.
There is nothing about the circuit that makes it incapable of driving these loads with low distortion however, it's just that raising the bias current would be optimal.
Thanks for the info.
What changes need to be made to increase the bias current? (I believe mine was a 4.1t version).
How much higher would you go? 75, 150?
Old 11th February 2019, 03:38 AM   #1472
OK I took a look at the notes in the spreadsheet and seems like I need to change R11, R12.
A few questions:
1) Based on your graph, 75mA seems insufficient still. Since it's hard to see where 14ohm lands on the graph, what would be the optimal value? I assume somewhere between 100-150 ?
2) I assume that even if I go for 150mA, the default R17/R18 of 4.75 should remain?
3) Is the gain calculation the same after changing R11/R12?
EDIT:
Just stumbled upon #5443967 and saw the values in the updated BOM.
I will follow that for 150mA...would appreciate any other thoughts worth considering.
Thanks!
Old 11th February 2019, 06:29 AM   #1473
To my understanding these headphones require 200mW @ 16ohms. Based on the graph, the 75mA is not sufficient but 150mA seems overkill.
Given the large caps required, perhaps 100mA or 125mA would be better?
Old 11th February 2019, 11:05 AM   #1474
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
My answer I tried to post earlier got zapped as diyaudio went offline for a while.
Anyway ... the latest BOM you can download from my website gives more info on the bias current mods. There is no change between it and the 4.1t BOM, other than the electrolytic capacitors have been reduced in number and increased in size.
But, no, no one "needs" more than a couple of mW of headphone output power. Much like solid state power amplifiers, its a question of headroom and dynamic reserve rather than clipping distortion. So it's a matter of will it sound better, which in turn is a question of whether the additional distortion and noise from running at higher bias current will or will not balance the reduction in distortion achieved by the increased headroom.
My recommendation stands: for 60-300 ohms, use the standard configuration. for 16*-60 ohms, use 75 mA.
*14 or 15 ohms, also. Close enough.
RJM Audio | phonoclone.com
Old 13th February 2019, 07:38 AM   #1475
Richard Murdey
rjm's Avatar
pcb-sapphire-42b2-bom
New BOM for review. I've changed the Power Options sheet to remove the 150 mA version, keeping the 37.5 mA and 75 mA version.
I've heard the story that the burger restaurants offer a choice of three sizes as a psychological ploy in order to upsell customers to at least buying the medium-size burger.
For the Sapphire amp, the same psychology was operating in a negative sense. The additional choice was causing indecision and confusion. It would be better to settle on just "regular" and "large" options, rather than "small" "medium" and "large". That way most people would go with the normal bias mode, and anyone who didn't would have a clear single choice remaining.
Also, the scaling was wrong anyway. As usual I was overthinking the problem. And 12 W heat dissipation for the stereo circuit at 150 mA is kinda nuts. 75 mA provides plenty of power into low impedance loads. Let's leave it at that.
Old 15th February 2019, 09:01 AM   #1476
Thanks for the update Richard.. the latest BOM is clearer.
Reading the power graph posted earlier, I was under the impression that both 37.5 and 75mA version would perform the same way for loads above 60ohm, thus the 75mA would be a more versatile choice for any headphone from 16-300ohms.
Does the 37.5mA perform "better" for high impedance cans because the extra headroom is not needed and distortion is added?
Old 16th February 2019, 07:08 AM   #1477
Silly question but which caps are considered in the power supply and which signal path ?
Old 17th February 2019, 12:01 AM   #1478
Richard Murdey
rjm's Avatar
@itsikhefez
1. That's a good way of looking at it: increasing the bias current widens the "useable" range of headphone impedance to include smaller values. While above 100 ohms or so the clipping level is unchanged with bias current, the distortion levels at lower output power does change with bias current. The relationship between distortion and current and load is complicated enough that I don't feel confident in trying to map it out, but essentially the optimal point is moved to larger output power as the bias current increases.
2. Formally only in the input coupling cap, C1, is in the signal path. I don't count signal return currents for this, so that's not to say that the others are unimportant ...
Old 2nd March 2019, 03:13 PM   #1479
ustas is offline ustas  Israel
Have a little question why trafos? Somebody use with RJM switching power supply 2A 12V?
Old 2nd March 2019, 09:26 PM   #1480
Richard Murdey
rjm's Avatar
Linear supplies are much less problematic re. RFI and sound good. I wouldn't recommend switching supplies, but you can do it if you want. Just remove the Z-reg section and use the main amplifier circuit powered directly from +/-12 V rails.
RJM Audio Sapphire Desktop Headphone AmplifierHide this!Advertise here!
RJM Audio Sapphire Headphone Amplifier rev14a1 kit rjm Group Buys 14 2nd September 2016 11:23 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
New Desktop Tube Amplifier, 6V6 SE Musik007 Twin Audio 11 6th October 2010 04:23 PM
FS: DIY Cavalli Audio Embedded Hybrid Headphone Amplifier sachi Swap Meet 4 19th May 2010 09:43 PM
Copyright ©1999-2019 diyAudio
