Headphone Systems Everything to do with Headphones
The Objective2 (O2) Headphone Amp DIY Project
Old 23rd September 2018, 02:52 PM   #5301
kiler is offline kiler
Also sorry for the double post but can't edit. The striped side of D3 reads 27.7 and the non striped part of D4 reads -27.7
Old 23rd September 2018, 06:11 PM   #5302
Mooly's Avatar
Those voltages are good. The regulators (the 7812 and 7912) need at least 15 volts to work, and less than 36 volts which is their maximum rating. So all good so far.
Next step is to check the regulator outputs which is easily done by measuring the voltage on D1 and D5.
D1 should have +12 volts on the non striped end and about +11.3 on the other end.
D5 should have -12 volts on the striped end and about -11.3 on the other end.
Those lower voltages (the - and + 11.3) should then be present on pin 8 of U2 (+11.3) and pin 4 of U2 (-11.3)
The Objective2 (O2) Headphone Amp DIY ProjectHide this!Advertise here!
Headphone amp project grahamfocal Headphone Systems 7 21st June 2011 05:28 PM
My latest project - DAC + headphone amp gmarsh Digital Line Level 105 13th December 2010 02:31 PM
My headphone amp project trifidmaster Headphone Systems 2 22nd December 2008 03:52 PM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 02:35 PM
Need help for a battery headphone amp project dismalonyx Headphone Systems 1 15th April 2004 11:22 PM
