Headphone Systems Everything to do with Headphones
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
Old 12th June 2019, 02:10 PM   #2691
snax is offline snax  United Kingdom
PM'ed
Old 12th June 2019, 02:32 PM   #2692
Malvin is offline Malvin  United States
PM'ed
Old 6th August 2019, 11:06 PM   #2693
Fsatsil is offline Fsatsil  United States
Ive been using my Wire for years without any issues until today. The amp hasn’t been used in a few months and I plugged it in today to listen to my HD600s and I got very distorted sound. I quickly unplugged my HD600s and shut the amp off, I checked the power supply voltage and sure enough I lost the negative rail. I remember reading a while back that someone had some power supply capacitors go bad on their amp. Does anyone recall or has anyone had a similar power supply failure? I’m going to pull the psu board this weekend to investigate further I was just wondering if anyone else had a similar problem?
Old 9th August 2019, 10:57 PM   #2694
spikestabber is offline spikestabber  Canada
Just have to say mine is still going strong and sounds as good as ever. I too run +/- 15V and also suspect I will have to swap those caps with something higher rated at some point. I've recently attached a relay based lineout/headphone switch + muting combo which turned out great in that it eliminated excess cabling.
DIY Soekris dam1021 dual-mono fully-balanced DAC with headphone amplifier (final) - Album on Imgur
Soekris dam1021-12v2 dual-mono balanced w/D882/B772 transistor mods & BAL-BAL Headamp: https://imgur.com/gallery/RVBQozq
nc400: https://imgur.com/iORCyna | TT2USB: https://imgur.com/a/p6OiS | HD800 | KEF R300
Old 21st September 2019, 04:26 PM   #2695
eimis is offline eimis  Lithuania
still got some of these boards if anyone's interested
Old 21st September 2019, 05:08 PM   #2696
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
I'll have to get a few boxes and get these shipped out.
Mark
www.kravchenko-audio.com
"The Wire" Ultra-High Performance Headphone Amplifier - PCB'sHide this!Advertise here!
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 47 12th April 2018 03:47 AM
Which Pass Aleph diy board for "no-cost-object" headphone amplifier? Hammerklavier Headphone Systems 43 7th August 2010 04:35 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 10:28 AM
My A.N.T. "Amber" headphone amplifier x-pro Headphone Systems 8 1st October 2007 09:47 AM
Copyright ©1999-2019 diyAudio
