Thanks Wayne! It’s WIP. I’ve been learning TinaTI and wanted to sim your circuit.Nice!
Where is the third transistor/Vbe multiplier? I see the "bias" port on the sch but no circuit.
You don't really need a servo in this circuit. The output Vos is low - it's the sum of the 1646 output offsets plus 1/2 the Vbe difference of the NPN/PNP output pairs. Typically its under 5 mV.
I would remove C2 and C8.
Noted about the servo, thanks! I’ll happily send you a board and source files once completed and tested.
Would it be worth adding
a). small start up delay on the power rails for just the the THAT1686 parts? A voltage ramp start to prevent compression driver damage? I think I can squeeze that from another dual transistor part and a few passives.
b). input level peak meter. Again from another dual transistor part and a few passives and led.
c). do the transistor banks need to permanently loaded with ?mA in any way to prevent shutdown?
I can't exactly remember what it was, but certainly no soundblaster...It was part of a professional two compound video + sound editing tv station rendering card, basically 2 cards of 30/10 cm size .I will look for the whole thing and tell you if i find it.I think it was something canadian...dreamth:
was that a soundblaster card?
Nice!
Where is the third transistor/Vbe multiplier? It provides thermal feedback. I see the "bias" port on the sch but no circuit.
Wayne,
Please find the thread here. 1st draft almost done. Some checking to do after sleep.
https://www.diyaudio.com/community/threads/smd-class-a-headphone-amp-that1646.384945/
Thanks, I didn't think that it was, based on some of the chips I saw in your picture. I was just curious, so no hurry.I can't exactly remember what it was, but certainly no soundblaster...It was part of a professional two compound video + sound editing tv station rendering card, basically 2 cards of 30/10 cm size .I will look for the whole thing and tell you if i find it.I think it was something canadian...
This was just half of the audio board which had some of the video processing on it too...ad811 , ad 828 op275 op-amps, ssm line drivers snd receivers...top of the line 2001 soundcard.the removed components were just some voltage regulators , two drv134 drivers and some ssm line receivers i used in a headphones amp made in 2012 that i gave later to a friend in 2015.Thanks, I didn't think that it was, based on some of the chips I saw in your picture. I was just curious, so no hurry.
Thanks!The 47 uF across the Vbe multiplier provides start-up delay.
How do you propose to heatsink all those SMT output transistors?
Lots of 0.15mm vias to 4 layers and a pool of potting compound… hopefully
- Headphone Systems
- Simple Class A Headphone Amp Using THAT1646
