Headphone Systems Everything to do with Headphones
Has anybody made an ELS headphone?
Old 4th February 2014, 11:53 PM   #451
Bibio is offline Bibio  Scotland
Bibio's Avatar
those are a work of art, stunning simply stunning.
i was looking at your stretcher and i thought that guitar tuning heads and saddles would work a treat.
this thread has been an inspiration and one day i will make a set.
Old 15th February 2020, 03:36 AM   #452
Marco audio is offline Marco audio  France
Marco audio's Avatar
Hello, still someone here ?
I want to build my own ELS headphones.
Old 15th February 2020, 05:11 AM   #453
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Hello! I'm still here. There are more discussions about DIY electrostatic headphones here: My DIY electrostatic headphones | Headphone Reviews and Discussion - Head-Fi.org
Old 15th February 2020, 10:21 AM   #454
Hello Chinsettawong,thank for reply.
Great website ,congratulations and thanks a lot.
For the moment i have recovered materials such phenolic,foam and wood.
I ordered 2um Mylar and pièces of 0,8mm glass fiber with a single layer of copper(for printed circuits)
I have Licron in spray can,nylon and brass screws.
I can use machines too.
I early started to build stators with perforated steel sheet:Thickness is 1,5mm,holes are 5,3mmx5,3mm squares,step between each hole is 8mm.I didn't find anything else.
Size of each stator is 115mmx90mm.
The area for the diaphragm will be 94mmx70mm.
Any review please?
For the moment i learn to draw with computer.
Later i project to build the amplfier, i have several russian tubes such 6n2p-ev and 6p6s,but my electronic knowledges are weak.
Regards.
Old 15th February 2020, 12:57 PM   #455
Try your own ideas and let us know how they turn out. It’ll be a lot of fun for you.
Old 15th February 2020, 03:45 PM   #456
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
I would like to see more amplifiers in this thread, I'm currently designing / breadboarding one with 6N6P.
Old 15th February 2020, 05:47 PM   #457
Hello, will you show a schematic please ?
Old 16th February 2020, 11:15 AM   #458
Miniwatt's Avatar
Yes, when I have a decent schematic. (And gone through the hassle of uploading it to a image host...)
Old 16th February 2020, 11:20 AM   #459
Cool, thanks
Old 20th February 2020, 02:40 PM   #460
Hello, i'm now learning about pp amplifiers.
I want to build my own full tube headphones amplifier.
Due to an order error i have some 6p7s tubes.
These tube can handle a big anode voltage:
500v max.
So i wonder if is it possible to use them In push-pull configuration with a single 6n7 tube ?(the 6H7C exactly)
1st triode as amplifier at entrance then cathodyne phase splitter for the 2nd triode?
Not so much power is needed for an headphone amplifier,10w or a few less should be enought,isn't it ?
I saw one unit who works with el34...
Has anybody made an ELS headphone?Hide this!Advertise here!
Never made anything before Moondog55 Chip Amps 5 3rd September 2007 03:45 PM
Where to have PCB's made? mirzametica Parts 5 24th July 2006 07:31 PM
Home Made Tubes?? has anyone made one, is it possible?? John Biles Tubes / Valves 7 11th December 2005 02:29 AM
i made it...!!!!!!!!!!!!!!!!! tbla Everything Else 21 20th December 2002 05:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
