May i confirm that the resistor installation instructions below for use with the comoco will not be applicable for the boards on this groupbuy #08? Thanks.
https://www.diyaudio.com/forums/gro...-ac-mains-120-230v-folsom-12.html#post5534060
I ordered direct by Coilcraft.com 39x 3717-AL but UK Warehouse. They arrived tomorrow but it seems that they only sell to companies because you are after your company sales tax no. questions that you don't have as a private . So the trick of simply entering your name at the company probably doesn't work. So it will be difficult to get some in the future for people living in the EU.
greetings from Germany
Dirk
Dirk
sierra_gva, Oversizing for amplifiers is good, for source components it doesn't help.
commstech, no group buy 8 doesn't require you to do anything like that. Just use the board as the silkscreen indicates.
dirks, just put your name in for the company name. Coilcraft has advised that should work to others before in previous buys.
it is a bit difficult to find approved x Caps thats fits in the Boards.
Someone had a link?
Best regards
DIRK
Are these OK?
B32922Y2474K000 EPCOS / TDK | Mouser Canada
Dan
Those look good.
- Group Buys
- GB: Round #8; Fo-Felix AC Filter
